S3 Steering Wheel - mode button
JoolsS3 May 17, 2009
  1. JoolsS3
    JoolsS3 New Member
    14
    I've got a standard Concert system in my S3 - when I press the 'Mode' button, the display shows 'NO FUNCTION'. Is this right - I would have thought you could alternate between radio and CD and possibly more?
    Is this a fault or is this the way it's meant to be?
    cheers!
  2. PTTM
    PTTM Pedal to the Metal!!!
    85
    Same thing happens on my A3 with mfsw and rnse with bose. Although i did manage to get it to change radio frequencies once i think. Not something i try to get it to do very often for obvious reasons.
  3. richs2891
    richs2891 I cant spell !
    441
    The mode button on mine activates the bluetooth phone.
    Not sure if can change what the mode button does.
    Richard
  4. Igdos
    Igdos Member
    323
    Think it only works if you've got mobile phone link up - NO FUNCT on mine as well.
  5. DaveS3Turbo
    DaveS3Turbo Sepang Blue S3
    1,065
    Yes its for the phone prep. I would be sure you can program the button to do something else other than being dead.
    David
  6. s8craig
    1,753
    55
    No you can't, it is only functional with the BT prep fitted.
  7. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    You can add a 'translation' box to make them do things... but that's not easy or cheap to do as a one-off.
    For example, I have a Parrot aftermarket bluetooth module which has a third-party steering wheel translator box to read the phone buttons... Now I can pick up, hang up, redial etc. from the steering wheel button.
    -Interestingly, the in-dash display still says 'NO FUNCTION' because the car itself doesn't "know" that something else is 'hearing' the same serial instruction and "making sense" of it.
    Not that button... but if you PRESS the thumbwheel NEXT to it, the radio 'SCAN' is activated... -I think you must have been confused and pressed the other button.
    Link to the kit which I have, incl. video showing installation and operation (not me or my car in the video)
    http://www.quickconnectproducts.com/Find/VWsteer2.htm
    Keith
  8. NHN
    29,352
    1,720
    Isnt it functional even for radio if BT isnt installed craig with a coding for the wheel?
  9. VWAddict
    656
    9
    I don't believe so: -I looked for anything pertaining to it under the VAG-COM and saw nowt...
    Keith
  10. NHN
    29,352
    1,720
    Ah hold on yeah the mode function is just to swap from radio to phone, so the left dial works for radio all the time anyway with no phone, as mode doesnt have another mode to swap to, silly me should have thought about that more.
  11. s8craig
    1,753
    55
    But it is still not functional or reprogramable to "other things", adding new hardware is totally different.
