JUS3IN
14.0 @ 98mph 2s 60ft
hey all, anyone following my other thread will know i removed the turbo from my apy engined s3 today, this is partly because i couldnt find a clear turbo out guide and partly to help me remember how to put it back... here we go bullet points!
head on! 3.5 hrs two/three (the third spent most of the time working on his own a3 turbo sport!!!) people, first time... lots of wd40 a few hours before start. turbo has also been taken off two years previous. engine cold, should have warmed it first but forgot.
*aquire beer
*charge pipe off
*turbo intake pipe off (tip) inc dv
*remove heatshield behind turbo, allen keys.
*remove wheel, wishbone three nuts, droplink x2 spanners, driveshaft (special hex drives buy these first) from gearbox end off, tie driveshaft up to spring out the way.
*crack turbo bracket nut x1 and turbo to exhaust manifold nuts x3
*remove downpipe (lamda?) sensor
*remove downpipe nuts x3, one nearest the fire wall is a nightmare all 16mm(rare but we used a smaller sparkplug socket to get the reach over the studs, will need a long reach socket.
*remove oil and water returns engine side through drivers wheel arch, easy allen keys.
*remove turbo to mani nuts, hex drives(like allen keys but not, get the right ones!)
*pull turbo back and remove oil and water feeds from the turbo on top, easy to see once the turbos loose! allen keys.
*remove turbo bracket nut 14mm, from drivers wheel arch.
*remove turbo
all done with the halfords proffessional tool kit except the drive shaft hex drive thing'ys and a few extra extensions.... all in all it was a nice day and went pretty smoothly other than my locking wheel nut being stuck which is irrelivent here!-)
*aquire beer
*charge pipe off
*remove turbo
