rough running v8
hondansxr Dec 11, 2012
  1. hondansxr
    hondansxr New Member
    19
    hi guys just picked up s4 2003 off flee bay there is no eng mag light coming on ,on ign or any time but airbag light is on .. have done a diagnostic check as it is running like its on 5 cylders (rough vibrating) 1st fault was camshaft sensor then no.3 cylinder cleared ran smooth for 10 sec then rough again .. did full diagnostic and central air flap motor fault and conrol module incorrect chassis ??????
    help
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    can you post log of the scan?
  3. hondansxr
    19
    "A" camshaft pos timing over advanced performance (bank 1 ) p0011
    just thought of something car ran fine reved /sounded ok then i did less than 100 yrds to petrol station and i put 60 quids worth of super unleaded (noticed the norm unleaded out of action ) could it have doggy fuel in it ????
  4. gen.heinz guderian
    1,346
    126
    how long you had the car?
  5. hondansxr
    19
    2 pm today drove from london to midlands
  6. gen.heinz guderian
    1,346
    126
    try some vpower or octane booster
  7. hondansxr
    19
    it was v power ? got some octane booster in garage will try that .
  8. hondansxr
    19
    will camshaft sensor make it run sound awful ?
  9. gen.heinz guderian
    1,346
    126
    not sure on a petrol,i had camshaft position sensor play up on my van, took 50+ cranks to start it with foot on accelerator, but once started it ran ok.
  10. gen.heinz guderian
    1,346
    126
    has the EML light come on?
  11. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    A few coilpacks faulty maybe?
  12. hondansxr
    19
    just undone the fuel pipe and spilt some om a kitchen tissue after a few minutes the tissue is still stained and when you rub it it feels slippy . should nt fuel just evap ?????
  13. gen.heinz guderian
    1,346
    126
    did it drive ok before you refuelled?
  14. adamss24
    adamss24 Well-Known Member
    4,561
    395
    It looks like you put v power diesel, however you should not been able to fit the nozzle in the filler but it can be done...
  15. hondansxr
    19
    would it not show on a diagnostic if coil packs were failing
  16. hondansxr
    19
    what would a tiny bit of diesel do to the engine ...misfire?
  17. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    If you'd put diesel in it, it would have white smoke billowing out the back. Coil packs are quite common for going, I may be wrong but I thing there was an Audi recall for S4 coil packs.
  18. fallmonk
    fallmonk Turbo Sport
    1,868
    Greeny is right there is a coil pack recall on that year don't assume because of the age it's been done , my 52 plate hadn't done ! Might be your problem and better yet its a freebie from Audi
  19. AlexGSi2000
    1,464
    199
    When I was a coilpack down on my 1.8T it didnt show on VAG-COM.
  20. jutlis 3.0
    jutlis 3.0 Member
    211
    vvt unit faulty
  21. jutlis 3.0
    jutlis 3.0 Member
    211
    mine was very similar and i ended up changing chains/guides/tensioners and cam adjusters
  22. docurley
    4,070
    85
    Buy a coil pack (always good to have a spare) and swap them out one by one and see if she runs better or try taking one off at a time and see if the engine note changes if it dose not then you have a bum coil pack.
