RNS-d and Gala Signal/ABS
ScottD3
Supporter
Plymouth
Website
wheelsnwires.blogspot.com
I don't know if its me, the unit or the car but the RNS-d unit is in and working but i'm not 100% convinced the sat nav side of it is working correctly.
It all appears to work but when travelling it's a bit slow at tracking my position on the map.
I assume it's meant to follow me like a normal sat nav unit but this one is always 30-60 seconds behind.
Cause the car is a 1998 and with no canbus system, I doubt the ABS speed signal would work so I changed it to Gala signal as the original stereo used this option.
Changed the setting via VCDS and went for a drive. Checked the speed signal via VCDS in mess block 06 (I think it was that one, what ever one it was that had speed) and it was 0.0 kph.
Changed it to ABS and it did the same thing.
I assume this is why the sat nav is not working fully cause its got no idea how fast I'm going.
Unless I've done something wrong, is it possible that the Gala signal is broken?
Is there any way to test it or wire up the ABS signal?
Any one got any ideas?
I was also getting no signal on the Speed pule wire, I used an meter and found that the wire was open circuit between the cluster & head unit, ran a new wire in and it's working fine now.
The Gala wire goes to the cluster?
I'll have to check that then.
Any idea what plug on the cluster?
PFL Cluster Pin out.
Multi-pin connector, 32-pin, blue
3 -Speedometer output 1
Going by the pin outs for the cluster. I assume this is the signal wire for the Gala from the clocks?
2 fault codes that I'm getting.
01317 - Control module in instrument cluster (J283)
49-00 - No Communications
00867 - Connections to ABS control Module
03-00 - No Signal
Sounds like some of the wiring is not correct or missing but what I'm not sure. May be worth posting in the NAV section, I've never touched the RNS-D only RNS-E & MMI.
Mine did the same
The gala appeared to have a signal because I wired it through funk switch and the LED would go out when stationary and increase in brightness as I sped up
Just disconnected it in the end as it works fine without it
Mine did the same
You're running with no Speed signal to the RNS?
How does the map work?
Does it keep up?
Mine says i'm on the A38 when I've pulled off and currently sat on the slip road.
Works fine
The speed signal is only there for when you lose signal in a tunnel etc
It takes a bit of driving to calibrate first use
I would look into the fault codes, I'm sure it's what is causing your problem. Looking at your posts you have had that unit in your car for a while so it should have calibrated by now.
This is my 2nd unit.
Its about 2 weeks old.
I got a third unit at home but I don't have the code for it. :(
A day is long enough for the navigation to calibration as long as you do a good few miles. s8craig may be your best help, or try a message on audiforum.us
Ours has just started actual showing us on roads and keeping up after 30-60 miles. I've not tested it past that, but quite happy. I just need a CD changer cartridge to test if it works with the ipod as we spoke about before. I didn't even realise the avant had one,lol
Yours has a working speed signal though.......or am fascinating on something that has nothing to do with it?
I left work today and set destination for Bristol but it never happened, it kept saying I was not on a digitized road but I've done about 30 miles with a CD in, so well see what happens.
Do yours at least show the car on a road? Ours was showing the pointer about 10 meters beside it, off roading we were according to it, and crossing bridges was awesome in the water,lol
I have read it will work with gala/speed, just i takes longer. Given that a normal sat nav has no gala signal to work out speed and direction, i see no reason why it won't work
So that could the first error code (01317), thing is they must be cheap enough now the RNS-D on ebay are only around £100.
So the final fault code could fix the problem.
One final thing to check, and I'm not sure if this is available on the RNS-D can you check how many satellites you are receiving, as it could be a bad GPS antenna.
You need to sort out the fault codes before, have you fitted a TMC module?
http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/112262-rns-d-retrofit-dis-problems.html
TMC is wired in but not coded.
It shows the car on or very close to the road but states its off road and always where I was.
I coded out my TMC as i don't have one. Silly expensive for something just to display arrows on my broken DIS
I will have that once I've done the facelift clocks.
I got full satellites, you can check it in setting, compass mode or when getting directions.
Here's what I mean when it's behind.
I'm currently on the ferry but landed at the dock side currently unloading.
Sat nav still thinks I'm in the middle of the rivers.
When you say full satellites how many is that. I get around 7-8 on my RNS.
562
551
