do you already have a revo map? depends on which one you get but you can select between std map and revo map, you can adjust the revo map - add timing/boost
I have one, yea they are good. if you use different fuels then you can switch map to suit and then you can have aggresive and smoother set-ups. make sure its the right one though as older ones just switch between stage 1 and stock.
