Retrofit CH/LH Issue.
micasb
So regarding CH/LH OEM switch i've got these 2 options that ELSA gives me:
For an 04 car:
Coming home button –
Pin 1 6-pin connector, black (C) (back of light switch) > Earth
Pin 2 6-pin connector, black (C) > pin 4 12-pin connector, brown (C) onboard power supply
Pin 3 6-pin connector, black (C) > pin 12 16-pin connector, black (E) onboard power supply
Pin 4 6-pin connector, black (C) > pin 3 12-pin connector, black (B) onboard power supply
For an 05/06/07/08 car Elsa gives this pinout:
Pin 4 6-pin connector, black (C) > pin 10 10-pin connector, black (K) onboard power supply
So where should i connect the switch's PIN 4?
Note i have K rev of J519 (09 module).
Regards.
Hi,
Anyone people? :bye:
Hope you can help
Best regards
wish i could help mate but don't know what would work on the 09module as haven't heard anyone done it yet
I've seen on ELSA that it just wires to the LED in the switch... So it can't be armfull if i try it on both connectons :).
In think i'll wire it like the most recent cars because i have a rev K central electrcis module.
I'll do this today and then i'll post it here.
Meanwhile if someone could help...
Regards.
Hi.
So i've oppened my old central electrics module and managed to figure out something usefull...
So PIN 10 on K connector goes to the KL30 relay wich i checked on ETKA as being a relay for interior lights...
Think i'll just follow the most recent wiring...
Regards.
Hi,
So this is solved.
I've connected as the more recent car and everything seemedto work fine, except the LED on tha CH/LH switch didn't work...
So i already had the rain/light sensor installed and had the wiring loom to put in. Done it and everything works like an OEM option :)
I also had to activate confort menu on 09 module so i could access DIS options, but now when i want to put front wiper into service mode it does not work... Any opinion?
Regards
12
892
816
