Retro-fit Nav system with SD slots
S4 SWO Jun 8, 2012
  1. S4 SWO
    S4 SWO Member
    47
    Evening,
    I currently have an 8P A3 but im looking at upgrading to an A4 avant. I've seen one I like in my price range with the high spec which I want... The only thing it doesn't have is a sat nav/ multimedia system.
    Now is this able to be retrofitted? And what would I actually need to complete?
    I also would want to get a system with SD slots.
    Ive done a search but haven't come back with anything.
  2. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    Ignore me I'm talking mince!
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    if you get a a4 with the hard drive sat nav you will get sd cards on the dash behind a flap with audi multimedia on it along with optional ami in the glovebox
  4. S4 SWO
    S4 SWO Member
    47
    I have already retro-fitted an rns-e system to my a3. But with the A4 2009 onwards, it comes with the screen in the dash, surely it's just retrofitting the nav unit in glovebox with SD slots?
    Rns-e system is the whole system including screen which is what I have in my a3
  5. a6_chris
    1,883
    160
    ah you want to fit the nav too, unfortunately its more involved than that, you need a new control panel, front dash, glovebox bits, rear modules in the boot etc .. will be the guts of £2k to fit and code .. better to get a car with it installed already
  6. S4 SWO
    S4 SWO Member
    47
    Well I've found the 3G nav system with 2 SD card slot on the bay for £595 which fits as standard in glovebox, I just didn't know what's needed to fit and connect to screen etc. I'm okay with coding as I have vcds.
    I believe all the navigation buttons etc are on the centre console?
  7. a6_chris
    1,883
    160
    You'll need the whole control panel down by the gear stick .. not an easy retrofit for basic users
    and if thats the module i see myself on ebay, thats for the a6 which wont fit/work in the a4 as the a4 sd cards are located above climate panel
    trust me, find a car with it already fitted, far easier
    control panel below the gearstick and note the audi multimedia panel above the climate control is where the sd cards go
