Retro Fit Acoustic Parking Sensors
dan888 Oct 18, 2007
  1. dan888
    dan888 New Member
    12
    Has anyone retro fitted these parking sensors to an A4?
    http://www.abacuscaralarms.co.uk/alarms/meta/reverse-sensors.htm
    If so I'd be interested in what they are like? (bearing in mind they are only £99 and can be fitted without drilling the rear bumper)
    And how you would wire them into the reversing light circuit?
    Dan
  2. Quattromaxx
    Quattromaxx New Member
    12
    did you decide to go with these, or did you choose something else
  3. Richardesty
    Richardesty loves quattro
    742
    20
  4. Quattromaxx
    12
    i went for original audi ones in the end they are well good pick up everything
  5. quattrojames
    14,050
    578
    Hello mate :hi:
    Any pics of them fitted?
    (I'm sure you have) ;)
  6. Richardesty
    742
    20
    :notme: as it happens, I'm halfway through relocating the 'wire' - cos I took the easy route first time, mounted it low down and ended up picking up the road when I backed out of my drive way........
    So - the green line shows were the sensor is now mounted, having passed it behind all the support moulding, the red line shows where I originally mounted it.
    Although I went for the one with the LED display :whistle2:
    If you look on the left you can see the 'end' of the sensor (C) sticking out from the tape - this just connects to a wire, which in turn goes to the control unit.
    For the new position, I taped the sensor to the end of a hacksaw blade, passed it through behind the moundings, then taped it into place using black Duck tape.
    And here's what it looks like when it's finished :
    :o.k:
  7. quattrojames
    14,050
    578
    Not exactly an easy fit then!
    They are certainly discrete! So discrete I can't even see them :keule: Where are the sensors in the bottom pic?
  8. Richardesty
    742
    20
    The very bottom photo shows the car once put back together. The whole idea is that you can't see the 'sensor' cos it's the metallic strip which mounted inside the rear bumper, as shown on the first photo :sly:
    Installation is really quite easy - once you work out where all the fixings for the rear bumper are
  9. quattrojames
    14,050
    578
    Ah I see, sorry my mistake. I thought you had fitted the ones from the bottom link that go on the number plate surround. Your's looks a very discrete clever system, do they work ok?
  10. Richardesty
    742
    20
    :no: Technically no 'they' don't.........however, 'it' works a treat :haha:
    (There's only the one sensor) :blush:
  11. dickys3
    2,963
    23
    Hi Rich,
    Atfer having them fitted for a while now, would you recommend them?
    Any issues with them?
    Rich.
  12. Richardesty
    742
    20
    Yes I would recommend the kit I used..........
    The only downside is false readings when the rear bumper is either wet, or indeed covered in snow!!!! :blush:
    Other than that - it's great :yes:
  13. dickys3
    2,963
    23
    Cheers. Think I'l order myself a kit.
    Rich.
