replacing tdi engine
rob0904 Jul 12, 2013
  1. rob0904
    rob0904 Member
    205
    13
    Hi, might have a chance to get an a3 with a seized engine. Does anyone know of a good guide knocking around on the web. Is there going to be any issues with replacing the engine or will it be plug band play as such?
    Any help would be great
    Rob
  2. <tuffty/>
    20,878
    3,701
    I doubt there is a 'guide' as such as engine swaps tend to fall outside the scope of a typical 'How To'... maybe worth grabbing a Haynes manual if you are particularly stuck but a like for like engine swap is relatively straightforward tbh...
    Never done a derv myself of course but can't imagine its much different to any other engine swap... if the engine is the same code then should be a case of the reverse of removing the old engine...
  3. rob0904
    rob0904 Member
    205
    13
    That's what I thought and hoped. some dervs have coded pumps and injectors I think which worried me more than the actual swap.
    Rob
  4. <tuffty/>
    20,878
    3,701
    Hummm... dunno tbh... like I said never done a derv so couldn't confirm/deny that...
  5. rob0904
    rob0904 Member
    205
    13
    Hi, still negotiating a price for the car. Its scrap really well to the owner that is, but seem to think it's still worth a lot.
    Been pricing up another engine which aren't cheap even for a bare one.
    Pretty good around a car, anyone have a rough time it would take to get the engine out?
    Dont want it sat for weeks in bits, as they misses would kill me haha
    Rob
  6. aragorn
    18,016
    714
    If you can operate spanners competently, and have a crane, you'll have the engine out, and the replacement back in, in a weekend.
  7. rob0904
    rob0904 Member
    205
    13
    Yeah I've done a vr conversion into a 1.3 mk2 so not to bad with the tools.
    Just a bit more involved with a tdi.
    Fingers crossed I can get a deal sorted soon.
    Rob
  8. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,814
    193
    If its the same engine, engine code would help at this point, then should be plug and play.
    If a different engine and ecu then youll need to reprogram the ecu or defeat the immobiliser.
    I put a BPX in place of my ASZ engine no problems at all.
  9. JimS3
    JimS3 Active Member
    736
    72
    Nope, no coded pumps or injectors.
    Removing / refitting the TDI lump is no worse than the 1.8T. If anything it's prob a little easier.
