Reesy's Big Turbo A3
Reesy Dec 1, 2011
  1. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Will see what's what when the Garrett comes off..
    To answer Stacey's question:
    (sunglasses at the ready, there is some seriously bright looking metal on the way)
    Top quality packaging matched with a top quality picture:
    Obviously they couldn't afford to spend much on the packaging as all the budget goes on the turbo's, which is good..
    Voila..
    Bad news:
    Wastegate is tiny, so could be in for some interesting 'creep' issues, but for just under 1/2 the price of a new Garrett core (at trade), it's worth a shot.
    Metal looks to be made from a similar material to the cheap spanner kits you see.
    The Garrett only lasted about 14 weeks, and it was off the road for getting on for 6 of them, so I have nothing to lose really..
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    The waste gate flap looks big enough , is the port inside small then? Get the dremmel on it if needed..
  3. Reesy
    3,640
    148
    Yeah the port is pretty small. I have Jay's dremel at the moment so i'll see if that's up to the job on the weekend..
    Looked at some other options, but not quite sure how I was going to squeeze this under the bonnet so decided against it..
  4. BENJAMIN
    BENJAMIN Active Member
    503
    93
    Don't think jays dremel could port a cheesecake. I'll get a carbide bit on it when I get a mo.
  5. superkarl
    superkarl MAN OF STEEL
    9,552
    2,449
    whats up with it? too small?
  6. Reesy
    3,640
    148
    Not going to fit a restrictor on this turbo, will see how it goes. There is not a lot of info available, so will go on the premise that if it starts smoking, it needs a restrictor.
    Does anyone know the length of standard wheel bolts? I have some 15mm spacers now so need some bolts..
  7. Jason.s
    Jason.s Active Member
    2,879
    348
    M14X1.5X27
  8. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    What's the new turbo? Is it simular to the Owens one?
    There's been some pretty good results with some of the eBay turbos :)
  9. Reesy
    3,640
    148
    • Compressor A/R=0.64
    • T25
    • Internal wastegate with 8psi actuator
    • Compressor .60 A/R cold side, ind 54mm, exd 70mm
    • Turbine .64 A/R , ind 52.90mm, exd 45.47mm
  10. superkarl
    9,552
    2,449
    is this a safe thing to do, a good way to approach the whole restrictor thing??
    this would be useful:Oil fitting kit, used to install test gauge on GT BB : atpturbo.com
  11. <tuffty/>
    21,562
    4,044
    Assuming its journal bearing (most eBay turbos are) and not a ball bearing then it won't need a restrictor... journal bearing turbos need the oil pressure to support the shaft same as big end bearings etc...
  12. badger5
    9,540
    2,016
    or is it.........
  13. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Any further updates Reesy?
  14. Reesy
    3,640
    148
    Updates are back on, Scott has fixed the issue I was having in that I couldn't open my thread...
    so basically the turbo is on, it's been on 6 days and nothing has blown up, broken, melted, set fire or generally gone wrong. Plenty of time for that though..
    the problem was the **** oil feed pipe I got. I didn't realise it was going to be as **** as it was or I wouldn't have bought it. Expensive lesson learnt and pirtek replacement is in use now.
    turbo is being run at actuator pressure, which seems to have settled at 15psi, but its terribly slow... Logging reckons flow for 280bhp, feels more like k03s power though, which is a bit **** when you have haldex weighing you down....
    need to gap the plugs as with the n75 plugged in it loves a good misfire.. Not sure what its wanting to boost too, a mixture of epic misfires and me being a wimp meant I saw 30psi approaching fast and backed off. Without the misfire I'll see what's what.
    The price of a garrett core means I might actually run this for a while, still undecided whether to sell the garrett or get it sorted at a later date, as this turbo is definitely smaller...
    all this in good time though, I need a month or so with a car as I was getting fed up of public transport and lifts... I'll post some pictures when I get the laptop out, but as of now the thread is back underway..
    ScottD3, s3dave and superkarl like this.
  15. superkarl
    9,552
    2,449
    Where the **** are you?!
    Tell me more about the oil pipe. What was **** about it? You made it yourself didnt you
  16. beachbuggy
    1,931
    201
    Is it a roller bearing garret?
  17. superkarl
    9,552
    2,449
    his new one is journal, chinese.
    Old owens one was BB, 3071chra
  18. Reesy
    3,640
    148
    Karlos, it was not the best quality pipe and it disintegrated. The bits blocked the restrictor and voila, one mullered Garrett.
    The replacement is from Pirtek and shouldn't suffer the same issues.
  19. Reesy
    3,640
    148
    Whilst the turbo change was happening, Ben also fitted the VVT back on the car, which might aid things in the future.
    Last night I changed the plugs, again, for the ones that Audi use as standard to see if it solved the misfire issue as the boost climbed with the N75 plugged in. Also, the correct banjo bolt for the turbo feed was fitted, which has stopped the slight haze I was getting from the car on idle.
    Actuator was adjusted as it was reading 15psi with N75 unplugged, so that it wouldn't overboost when the N75 was plugged back in. Took the car for a drive and it was still misfiring a bit at first, but seems to have sorted itself out so the plugs change was hopefully a success. Car does have a strange issue though in that you can feel it holding back as it's climbing through the revs, it's not a misfire but you can feel it not going like it should.
    If i get time today I will do some logging and see what's what..
    Alllllllso, after buying this stuff ages ago, but not really wanting to put it into the engine mounts as fiddly jobs like that are ****, Ben said that his dad was keen for jobs like this, so I have ended up with a set of these:
    He left a bit seperate and **** me is it hard, I have a very strong feeling it's going to be unbearably rattly in the cabin.
  20. Reesy
    3,640
    148
    I'm beginning to like this turbo..
    I fitted some tfsi coils at the weekend to cure a slight misfire the car had and replaced a breather hose that had split and was stinking out anywhere within a 5m radius of the bonnet everytime the car was stationary. Both were a success. Logged the car, and apart from a slightly odd lambda reading at about 5k which Ben thinks could be the cause of why the car still feels like it's holding back a bit, it's running well. VCDS logs suggest airflow good enough for 327 bhp, which at somewhere between 21 and 23 psi is pretty healthy..
    It's good enough to nearly crash when exiting a bumpy roundabout, flat out through second and third, in the pissing rain. Apparently.
    It's also good enough to **** off an S3 owner at motorway roll on speeds :arco:
    kwistof and StaceyS3 like this.
  21. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    How are you finding your (Ben's dad's DIY) upgraded engine mounts?
    Did you use any adapters for the tfsi coils as well?
    They are both definitely on my (Ben's) list of things to do next! lol
    Ohh- and I hope that was an 8P S3 owner....they're the easiest to **** off :)
  22. Reesy
    3,640
    148
    Not fitted them yet, haven't got round to it. I've been pretty busy and it's made a change to mainly just drive the car..
    I did, but you don't need them really, they just look a bit pony without them.
    Nope it was an 8L
  23. kwistof
    2,434
    535
    Lol- that's what I thought about the adapters....I will probably end up following the same route and purchase them.
    Were they an Awesome GTI purchase or is there anywhere else to get them cheaper? (although they seem very well priced already on their website)
  24. <tuffty/>
    21,562
    4,044
    OE ones are like a couple of quid each...
    http://www.audi-sport.net/vb/a3-s3-...4-2-0-tfsi-coil-packs-1-8t-7.html#post1813440
    kwistof likes this.
  25. kwistof
    2,434
    535
  26. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    Rees bag, What's happening with your Denim Avant?
    Jason.s likes this.
  27. Reesy
    3,640
    148
    Got it cleaned and removed loads of **** from the car and boot.
    today Ben dug out a bleed valve and fitted it to the avant, after some tweaking the car now sits at 28ish psi and is officially a maf maxxer. 290 g/s at 6300 rpm and all is good.
    superkarl likes this.
  28. Prawn
    11,574
    3,544
    Beast. Not bad for a denim ebay ****ter ey? :laugh:
    You got those mounts on yet? I fecking love mine.
  29. BENJAMIN
    503
    93
    Had to give reesy the 'dad chat' last night. "You are going to crash this car very soon, 30psi mid corner is not going to end well"
    CHEZ likes this.
  30. Prawn
    11,574
    3,544
    Haaaaahaaaaaahaaaaaaaa.
    Youre a good Dad to him, I forget he's only 12 at times :laugh:
    fake 4wd is for straight lines only Chris, everyone knows that :superman:
    CHEZ likes this.
  31. ScottD3
    15,162
    1,123
    And snow.
  32. Prawn
    11,574
    3,544
    I couldn't agree more. Snow is also good for straight lines :iagree:
  33. Reesy
    3,640
    148
    30psi is good for corners too, Ben was just being a wimp because he was breaking the law and not wearing a seatbelt..
    You'd be surprised how well it holds on, managed to get some tyre squeal yesterday but apart from that it grips and grips.. If it does go though, the haldex is so unpredictable I don't think it'd end too well. Once the novelty of 350+ has worn off, I'm sure I'll go back to more sensible driving.
    Oh and I didn't mention that a slight exhaust blow was fixed... 5 bolts holding on the downpipe: 2 were loose and 1 was missing so the exhaust gasses were blowing straight up into the bonnet! Ben fitted another bolt and tightened the two that were accessible, which seemed to make things better. Other 2 presumed loose, but inaccessible so were left alone.
  34. Reesy
    3,640
    148
    CHEZ likes this.
  35. Jay A3
    2,130
    356
    Actually looks clean
  36. ScottD3
    15,162
    1,123
    Its clean and looking good.
    You feeling ok Reesy?
  37. *P3nfold*
    *P3nfold* Member
    368
    15
    Chris your car is mental, sitting in the back while you are driving is really taking your life in your own hands, just saying buddy!!!
  38. Reesy
    3,640
    148
    Thanks Martin, glad I scared you.. It's gained about 8psi or 30+ bhp since then so it is even more exciting.
  39. CHEZ
    CHEZ moderately amusing Supporter
    4,172
    840
    yeay! got to love a sleeper!
    reesy your's is a sleeper!
    stealth woop ass FTW!
    Reesy likes this.
  40. *P3nfold*
    *P3nfold* Member
    368
    15
    lol your mad fella, just want to point out on ASN if you drive a 3 series 2.5i stay out of his way.
