Always had an issue with the rear passenger light on my 2004 avant.
Intermittent bulb warnings.. turns out to be an iffy connection because the connector catch into the bulb holder is broken so it doesn't clip & hold in place.
Over the years I have just wrapped some tape around it & it's held fine until now.
Currently i'm getting intermittent 'Left rear light' warning & the whole cluster is going on & off which isn't good!.
Is it possible to replace the wiring with the connector on? as it goes into a rubber grommet & into the bodywork of the car, is that a big job? if so i'll get the tape back out again tomorrow & try some fresh!
