Any change in EGT's or IAT's from leaning it out a bit with the 3 bar FPR?
Do you even need to use the WMI if your IAT's aren't shooting up?
If everything looks look on the gauges and logs just keep the 3 bar regulator in.
Is there even any point changing engine management if you're not changing the turbo for a bigger one?
Mild increase in EGT's as you'd expect when removing a **** load of fuel cooling, but when i say mild, it's risen from mid 700's to 800 at the end of a redline pull through 2nd-4th, measured at the start of the DP. This is where it's always run historically and doesn't creep up much beyond that ever regardless of how hard it's driven.
WMI - yes. I'm absolutely always going to use it, whether technically required or not. It's a safe guard that keeps everything colder, provides ultimate resistance to knock, and allows me to lower EGT and make power through safely running lots of timing, in turn meaning the boost requirements arn't silly high so the turbo isn't a total heat pump. It's win/win/win on that front and I don't intend to run on track without at all.
I'm at a stage where I don't want to be reliant on ALWAYS having to book in to a tuner to make any small changes / tweaks every time I change anything on the engine, or worse, as the case has been, avoid making any changes at all because of the complete lack of support for the crappy 3.8 ECU these days.
I want to be able to play with settings, change parts and around and make small tweaks, build up a library of different maps that give me different delivery options.
I want to experiment on the road with different boost profiles, wet weather setups, all sorts, as well as gain the safety of closed loop fuelling and EGT control.
ME7.5 can do many of these things, but learning all the definition files as well as the mapping aspect is more hassle than I want, and if you don't do it yourself then you're still 100% reliant on A N Other.
I want to go stand alone, and spend a while fiddling myself and get it somewhere at least half close. Then spend some time on the dyno to tune it to effectively it's max, so I know what's safe and what range I can safely experiement within also.
The ME3.8 is a problematic ecu at the best of times. peak boost can vary massively not just day to day, but each time I put my foot down. it won't adapt, it's difficult to map, it's just generally a bit crap.
I also get to ditch the annoying MAF!
Put simply - I've come to hate 3.8, and I want out!
We shall see what happens.......
