Polished Bliss: Phantom Black RS4
WX51TXR Jan 16, 2009
  1. WX51TXR
    WX51TXR Polished Bliss
    1,452
    15
    Done by Clark this week, posted by me:
    Hi guys, been keeping a bit of a low profile recently but decided this would make for a nice write up :)
    Car: 3 year old Audi RS4.
    Detailing Service: 3 day Major Paint Correction.
    Monday morning began with the pre-foam, using Meguiars APC through the foam lance at 60 degrees:
    This was left whilst I filled up the two buckets for the wheels and then rinsed off at high pressure, taking a good 10 minutes to cover every inch of the car to ensure as much dirt and grime was removed.
    The wheels were then cleaned with Meguiars Wheel Brightener (10:1) and the arches/tyres were done with Meguiars Super Degreaser. No Pics of this stage as I had to put my camera batteries on charge.
    The engine was next, which was rinsed at medium pressure after being soaked with Super Degreaser:
    Super Degreaser was used once again for the door shuts. These were left for a couple of minutes...
    ...before being rinsed at low pressure:
    All the exterior trim/badges etc were then cleaned with APC and a Meguiars Slide Lock brush:
    I then washed the car with the 2 bucket method and Menzerna Shampoo (using up old stock) then rinsed.
    The first signs of the condition of the paintwork were becoming visible now the sun had come out:
    I then finished off the wash stage by removing some minor tar spots from the paintwork and wheels with Autosmart Tardis and then put the car inside after a final rinse off.
    Gloss-It's aggressive clay bar was then used to remove bonded contaminants from the paint and glass, using Last Touch as lubricant.
    Paint depth readings were then taken with all the metal panels showing healthy levels and the plastics were similar:
    Now it was time to assess the condition of the paintwork:
    Some areas weren't too bad, with just some scuffs and the odd scratch or two:
    Other areas were worse, with significant signs of incorrect rotary use over the majority of the car, plus some nasty RIDS here and there:
    I then gave the paint a thorough wipe down with Menzerna Top Inspection as I've noticed Last Touch (if used during the claying stage) can cause problems with polishing now and again and it can also prevent the masking tape from sticking to the trim properly. The Top Inspection just removes any traces of LT and leaves the paint squeaky clean :)
    Correction of the paint was carried out with a Menzerna Polishing Pad and 3M Fast Cut Plus mixed with a bit of Ultrafina. This was worked @180rpm's with some sections needing 2 hits before I was happy:
    Before:
    After:
    50/50 on n/s wing:
    A smaller compounding pad was used for the bumpers and tighter areas:
    The front fog light grills were removed to gain better access to the lower parts of the bumper:
    Bumper fully corrected:
    I gave the headlights a light polish with Menzerna 85RD RE5 to remove some light bug splat etchings:
    A 3m Compounding Pad was used for the rub strips:
    It's important to keep the rotary moving quickly over these parts to prevent heat build up and potential delamination.
  2. WX51TXR
    1,452
    15
    The lower halves (including side skirts) were also done with the 3M pad, some deeper marks remained but overall I was very happy with the level of correction:
    After close to 17 hours in total, the first stage of correction was complete.
    The second polishing stage was then carried out using a Yellow 3M Polishing Pad and Menzerna PO85RD RE5.
    Out came the wool duster to remove all polishing dust once complete:
    Top Inspection was then used again to ensure the paint was free of all polishing oils:
    With the paint and glass now completely free of dust and oils I applied the LSP. This was to be Zym0l Vintage applied by a Blackfire LSP applicator pad:
    This was applied to the whole car:
    It was then buffed off after approx 10 minutes.
    Whilst I'd been concentrating on the paintwork, Marsha had some spare time so she sealed the wheels (Blackfire Metal Sealant), dressed the tyres (3 coats of Gloss-It Signature Tyre Gloss), polished the exhaust tips (meguiars NXT Metal Polish) and shampoo'd the interior mats.
    The interior was also detailed, including the leather, which was fed with Raceglaze Leather Balm:
    The engine bay was dressed with 303 Aerospace Protectant:
    The paintwork was then given a final wipe down to remove any fresh oils from the wax "gassing" and then out came the camera for the after pics :D
    A quick walk round the car with the Sun Gun to show the true condition of the paintwork (temperatures had dropped significantly so there were still a few very light smears after the wipe down and I wasn’t prepared to marr the finish by trying to buff them off again):
    Roof:
    Bonnet:
  3. WX51TXR
    1,452
    15
    Then out came Rich's SLR and I tried to do my best David Bailey impression :D
    Total Work Time: Approx 33 hours (Including a 1am finish on Tuesday!).
    Thanks for reading :)
    Clark
  4. kaz219
    kaz219 Active Member
    1,808
    Awesome work mate - came out really really good :D
    look at the shineee :jester:
  5. Toxic
    Toxic Member
    54
    :hubbahubba:
    that left me speechless
  6. NHN
    29,577
    1,779
    Absolutely brilliant fella, really is a fantastic job, not that your previous ones were any less of a good job but for me this is one of the best I've seen, 1st class work
  7. quattrojames
    14,068
    585
    Lovely job! What a transformation.
  8. Quattro_Ollie
    Quattro_Ollie New Member
    17
    Cracking job, looks the business
  9. S3 LTN
    S3 LTN Member
    Wow.. Amazing..
    Oh tight jeans!!! :redface:
  10. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Well done dude, looking good.....as always!!
  11. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Awesome
  12. StagsyA4
    StagsyA4 Member
    96
  13. aldo286
    aldo286 Member
    86
    megs all purpose cleaner mate ;)
  14. docurley
    4,073
    88
    I know this is a bit late but I came across this thread when doing a search on google images for something else but dam this is great work, don't want to even ask what a job like that would cost.:applaus:
  15. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    Excellent work - only just checked out the detailing section on here, but I'm on DW too.
    Just got myself a DA to correct my Phantom Black A4.
