only 5psi of boost
Plunky Nov 1, 2010
  1. Plunky
    Plunky Member
    522
    I started using the a3 today after 2 months of it being sat. I had to jump the battery as it was dead but afterwards all seemed fine, I let her warm up and then proceeded to go for a drive but then realised the car was only producing 5psi of boost under load in all gears. I realise the boost is running off of the wastegate pressure and bypassing the n75. I have changed the n75 but still the same problem.
    Any ideas?
    Liam
  2. aragorn
    18,490
    855
    fault codes?
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Limp mode at a guess
  4. Plunky
    Plunky Member
    522
    Havnt scanned it yet. How would I get it out of limp mode? Vagcom needed?
  5. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Yep, fault codes. Why hunt for a problem that the ECU may tell you in 2 minutes?
  6. Plunky
    Plunky Member
    522
    used the car this morning after having the battery on charge all night due to it being flat. Its fixed itself! :D boosting like it did before, perfect!
  7. Prawn
    11,575
    3,546
    awesome news Liam.
    If you want to pop round one night and scan it just give me a text. Can get that bonnet strut too!
    Plus, I want a ride whilst you've still got it :)
