oil pump failure on 2.0Tfsi 2006 A4
imran999 Mar 14, 2014
  1. imran999
    imran999 New Member
    24
    Is oil pump failure a known issue on the petrol engines?
    My pump has just failed at 95k and i am looking at a 2k bill to rectify damage caused
  2. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Yes, apparently.....which engine model do you have out of interest?
    BR
    A
  3. imran999
    imran999 New Member
    24
    engine is the 2.0TFSI with 220bhp Special Edition (same as DTM)
    Not sure which engine code, but it is one of these engines ... apparantly all carry same oil pump
    BGB, BUL,BWE,BPG,BWT,BYK,BPJ
  4. Molnboman
    1,338
    193
    That will be the BUL engine I think.....not one of the guilty codes normally. Did you have full service history and stuff?
    A
  5. imran999
    imran999 New Member
    24
    last service done at indy, next service due in 2k miles.
    Only ever took car to audi around 3 times. I doubt they would offer me any compo
  6. Giosabcsl
    Giosabcsl Active Member Audi A4 saloon
    853
    156
    43
    You never know unless you try.
    Did it happen when driving or just starting the car?
    And were there any signs of low oil pressure warnings on the dash?
    If you have the 220 hp then its most likely the BUL.
    It usually was not common for the oil pumps to go on cars above 2006. But it seems more and more are creaping out I think this is the 5th or 6th gone this year from my knowledge.
    2k is not that bad considering the uprated unit oil pump is £1005 trade price.
  7. hades-
    9,481
    646
    was it the oil pump or pick up pipe that failed ?
    all the 2.0 are known for both to fail
  8. hades-
    9,481
    646
    the price you quoted above is for the diesel pump
    the petrol is known to go and pick up to get blocked
    and no where near £1005 for a petrol oil pump
  9. Giosabcsl
    853
    156
    43
    So what is the price then?
  10. hades-
    9,481
    646
    just over £100 not fitted
    but his 2k price is cos he will need new turbo etc etc
  11. Giosabcsl
    853
    156
    43
    We must have our wires crossed.
    Are you talking about the actual pump or the pick up tube or something completely different.
    Because im talking about the following part number:
    06B103535F - £838.33 trade price = £1006 with vat from tps
    06D103295P
    I know the pick up tube is the following part:
    06B115251B
    And that is around £100
    Let me know because if its 100 quid im buying loads and storing them.
    This is what I was referring to Original VAG 2.0 TFSI Oil pump balance shaft module 06D103295S | Clearance | LOBA Motorsport GmbH
    Not that exact part number but that unit.
  12. hades-
    9,481
    646
    I'm on about the oil pump that includes the pick up for the petrol engine iv got a recipe from Sheffield Audi from jan 14 £126.94 plus vat the diesel pump is over a grand
  13. hades-
    9,481
    646
    That price if over a grand includes the balance shaft unit aswell
  14. Giosabcsl
    853
    156
    43
    Yes the 1k prices includes everything balance shaft, oil pump, pick up etc
    Could you possible check for me the part number on your recipe. So I can keep it on record.
  15. Raymond999
    Raymond999 Member
    65
    9
    Diesel oil pump on its own is £180 just had one fitted at vag specialist.
  16. imran999
    imran999 New Member
    24
    I went to see the car today. Indy has stripped car down and removed sump and oil pump. The oil pump in my car is chain driven and I believe this was changed to gear driven the following year. The chain that drives the pump on mine had snapped and this caused the chain guide to break and the sprocket/cog to be bent.
    A new oil pump is indeed over 1k cost. (audi quoted me £1200 for 06D103295P which is pump and balancer shaft).
    Indy is trying to see if he can get the pump repaired somehow otherwise it will need a new pump and chain etc.
  17. imran999
    imran999 New Member
    24
    The chain snapped on it causing quite a bit of damage.
  18. imran999
    imran999 New Member
    24
    Some pics of damage to chain cog of oil pump
  19. Paranoid69
    Paranoid69 Member
    79
    My BGB recently failed, on dismantling it seems it may be just the pickup partially blocked as the pump and shaft seem intact. Still need a new head due to collateral damage though.
  20. Molnboman
    1,338
    193
    That's a bummer....I tried to get the sump off my BGB engine last winter to change my pick up strainer.....and gave up...I couldn't manage to remove the sump cover as there was two bolts which were hidden and near impossible to remove at the clutch end....wish someone could solve the mystery for me on the BGB.
    BR
    A
  21. hades-
    9,481
    646
    to get the 2 bolts out you need to remove part of the gearbox
    or you can cut the smapp piece of metal thats hideing them
  22. Molnboman
    1,338
    193
    Cheers Bez.....I vaguely remember giving up at the point.....really frustrating they designed it that way.....or was that to deliberately give the garages more labour hours....cause other VAG petrol engine sumps are not so difficult to remove.
    A
  23. imran999
    imran999 New Member
    24
    on my engine, the mechanic had to drop the suspension to get sump off. Not sure if that's due to the Quattro though.
    On a side note, I discovered powermax engineering in Ireland...who seem to be selling repair parts for the oil pumps
    Audi Vw 2.0 TDi Oil Pump Problems, Chain Repair Kit, Gear Conversion, Balnce Shaft Repair,
  24. hades-
    9,481
    646
    iv used powermax a few times for parts
    good service
