number plate light bulb holders
Leaky Lloyd Sep 24, 2010
  1. Widemonkeys
    Widemonkeys 1st Gear
    271
    Mine came today top man
  2. coyote
    coyote Member
    217
    This thread finally gave me the motivation I needed to buy the parts and get the tools out this morning. I now have 2 fully working numberplate lights.
    Cheers guys:icon_thumright:
  3. Widemonkeys
    271
    I've got the tool and parts but can't get the boot plastics off!!!
  4. coyote
    coyote Member
    217
    Undo the 2 screws under where the warning triangle goes, and 1 screw in each of the handles that you pull the hatch back down with.... then pull the bitch off
  5. Widemonkeys
    271
    I've tried but i don't want to break the boot cover.
  6. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Don't worry, it's secured with retaining clips on the back so you will have to pull it off - it's stronger than you think, but once you've got your fingers under and pulled one off the next are real easy.
    PS. I've just read this message back to myself and I'd like to say "no puns please!!"
  7. Widemonkeys
    271
    Ha ha very good, I'll give it a go on Tuesday and let u know
  8. quattrojames
    14,050
    576
    This might help you with the tailgate trim:
    Northampton_ofn likes this.
  9. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    Finally got round to changing my old damaged panel, i broke it months ago trying to get the screws out. All changed now.
  10. itsmeagain
    434
    Now my LEDs are not working, got only one working. Must be a dodgy bulb, gotta order some more now.
  11. CHRIS555
    1,970
    10
    Just thought - your bulbs are probably ok - when I did mine they did not work - it turns out that the lense metal pronges can easily miss the contact point within the moulding wiring - i was 100% sure i did mine right - I had not!!! I took the moulding off and took it in the kitchen and put it under some lighting - there are some spaces / gaps on the back of it where, with the help of some light, you can see if the contacts are "contacting" and mine were not, on either of them!! Basically you just need to play around with the long metal prong until it touches, and hey presto all sorted!
    Apparently this is a common problem as well - especially if you have changed the light covers for new ones, like me, as the new ones have slightly different length pronges.
    Try this before buying any more bulbs, hope it works
  12. Widemonkeys
    271
    Finally got it done what a Pratt on. All the nuts were corroded nd wouldn't come off! Took me 2 hrs. Worth in the end thow can't wait till it's dark
  13. itsmeagain
    434
    I am gonna have another look tomorrow, hopefully that is the problem
  14. Shane-Ireland
    Shane-Ireland Member Team Ibis Team V6 Audi S3 quattro Audi A4 Audi Avant Owner Group TDi
    270
    22
    Chris is spot on here,one of mine proved a right bitch,i had to bend and re shape the prongs so the would contact and even noe sometimes if i slam the tailgate too hard that one goes off for a second!!
  15. itsmeagain
    434
    Thanks mate my bolts arrived this morning, fitted perfect. Only problem is that my stupid bulbs are playing up now, gonna just order some more bulbs.
  16. quattrojames
    14,050
    576
    New LED bulbs? Check.
    New light lenses? Check.
    New screws? Check.
    Copper grease? Check.
    You know when sometimes you wonder why you bother? :(
    Screws were solid as expected, so I drilled around the lenses, and got one of them out, the screw was still solid and even with mole grips wasn't budging. And then it sheared off.
    So tail gate trim out, undid lock mechanism etc and found this:
    WTF?
    This is in such a bad state I'll have to replace it, so stuck now till I can get to the dealers on Monday :ohmy:
    It's appalling how bad these get.
  17. CHRIS555
    1,970
    10
    Yeah, thats not good - just so you know in advance you'll need to take off the wiring loom on the moulding - i'd give this a really good clean and looking over - i actually bought another wiring loom (because i'm fussy) to go with all the other new parts, I think it could around £25
    Good luck mate - welcome to the strange tormenting world of "changing a lightbulb on an Audi!!!"
  18. itsmeagain
    434
    That looks like its been at the bottom of the sea for years. LOL
  19. Widemonkeys
    271
    Thats what mine looked like except when mine came out it had a big crack in and snapped in two.
  20. quattrojames
    14,050
    576
    Thanks for the tip. I'll have a good look when I transfer it across, at the moment it looks ok, but I didn't want to start removing it until I have a like for like part to transfer it too.
    I'm just glad that none of the corrosion has transferred itself to the tailgate, or else I'd have been forced to buy a Euro style one.......
  21. scott b
    scott b Active Member VCDS Map User
    1,254
    going back to were people have said use m3x20 bolts to secure the number plate bulb holders insted of audi the screws, i tried this yesterday and it seemed that they wouldnt grip into the plastic were the screw had been?
  22. quattrojames
    14,050
    576
    Do you mean the plastic of the light lens? Or the metal/aluminium of the lamp holder?
  23. scott b
    1,254
    light lense
  24. Gaz!
    Gaz! Member
    159
    14
    I dont supose you have any of these screws left have you mate? Im having to do this as now neither of my bulbs are working.
  25. quattrojames
    14,050
    576
    I always like to end on a happy ending!
  26. quattrojames
    14,050
    576
    All back together and debadged too:
  27. swarcup
    swarcup Well-Known Member
    1,326
    40
    You missed one. lol
  28. quattrojames
    14,050
    576
    It looks plain with nothing there IMO.....
    I might rebadge it 4.2TDi :unsure:
  29. simon.m
    simon.m Active Member
    2,747
    i thought that when i first took all mine of james so stuck the s one on mine from the s4 ;-) does take a bit of time to get used to it but is better for cleaning too 4.2 a that would worry a few when thinking about get you of the lights lol :blackrs4:
  30. Shane-Ireland
    270
    22
    20mm are too long the screw/bolt will bottom out not allowing you to screw it all the way in.
    I do PM me your address and i'll sort you out.
  31. itsmeagain
    434
    Finally after my new bulbs arrived this morning, I now have working bulbs. I played around with the metal prongs on the bulb holder and hey presto they worked. I can put my number plate back on now. LOL
  32. CHRIS555
    1,970
    10
    Good man!
  33. quattrojames
    14,050
    576
  34. simon.m
    2,747
    wow i bet they would be brite
  35. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
  36. Turkster
    2,797
    47
  37. CHRIS555
    1,970
    10
    Nice!
  38. Shane-Ireland
    270
    22
    hex heads FTW lol
  39. quattrojames
    14,050
    576
    I'll be removing mine and regreasing once a month from now on!
  40. Turkster
    2,797
    47
    LOL
