Not another Nogaro!!!
is brake assisted steering part of traction control, terminology wise - or ESP? in my old C Class BAS and TC were different buttons. Not sure how to ever prove that such a technology works - surely it is just a last gasp correction before the accident?
ESP is essentially an anti skid system...
PDF here all about it...
http://www.volkspage.net/technik/ssp/ssp/SSP_204.pdf
The button does nothing as ESP is now off completely (ESP is traction control on an S3)...
I believed it works as ESP in case of swerve (reducing power and braking wheels) and as TCS in case drift wheels only (some other cars has two different steps pushing ESP button for different amount of seconds: the first one disable ESP, and the second one turn off TCS too: old BMW's DSC works in this way). So on ours S3 8L the ESP is completely turned off pushing that button one time only, ok thank you.
This would have to be one of the best interior upgrades thus far.
Yes i know there is liquid gauge and FIS-control that are plug and play - but with some effort (a fair bit actually) and 3 days later. My cluster is now fully functional as a digital display for pretty much everything you need.
Here we go - ColorMFA
Reactions: feck_on_a_stick, Alex C, Sam_ and 4 others
nice actual work dude... where did you get that from?
...and whats with the some what phallic looking device in the middle?
Reactions: IPG
Smart job mate.
How long before you work out how to change the car symbol from silver to Noggy :nogarors4:
Reactions: IPG
Would be interested for a link for the dash instrument upgrade that looks wicked.
Reactions: IPG
Wow that's just so awesome !!! Well done
Reactions: IPG
hahahaha microphone for handsfree. i figured right in front of my face would be the best place for it to pick up my voice for calls and voice commands.
Smart job mate.
hehe i already have the "program" or whatever it is to make DIY startup logos - i think i was the S3 logo... maybe in a noggie blue "S"????
Here is the link where you can order - https://www.drive2.ru/o/b/462034853152424107
Google tranlate is the key
Thanks :) Took a while to muster up the courage to do it (as you saw in the video it's quite involved) but well worth it!!!
Just ordering the ****** thing looks more involved than fitting it tbh lol
hahahah
just shoot them a message and wait.
the worst is that there's approx. 2 month waiting period.
hahahah
damn okay 2 months wait then send my cluster over to you to get done :notworking: hahah
really loving the mods on this car and the route you going with it :s3addict:
Reactions: IPG
:openmouth::openmouth::openmouth::openmouth::openmouth: Amazing !!
Im Guessing the new daughter board grabs the signals directly from the pins of the blue, grey and green connectors (totally bypassing the old fis connection) , I see it only work with the facelift dis clusters also :disappointed: ! guess its time to start hunting for one :grin:
you are really raising the bar with your car :sunglasses:
Reactions: IPG
Incredible!
Reactions: IPG
Correct - they connect to the pin outs of those connectors. SO would anyone know of this means the setup will work with aftermarket ECU's??? I have some friends who are wanting the screen however have "upgraded" to Link ecu. I'm not sure if the signal is first processed by the ECU to be send to the cluster. I'm guessing it is making this compatible only to for OEM ecu setups.
You can see I was a tad rough when removing the old screen - I lifted contacts left right and centre but all the lights that I needed working are still ok so it completely does away with that obsolete red and yellow screen!
I am actually taking down names to make a group buy so if you're not in a rush and wanna do it. Then yeah I'll be happy to help out but I am in Australia. Lol. Probably best to find someone more local or just give it a go yourself?
I'll make a write up here so you can have some guidance.
Reactions: TurboLover
After going on the link you've provided I'm still not 100% sure what I'm supposed to be looking for lol. Am I supposed to send my clocks off and they do it or am I paying for new clocks with the aftermarket cluster in the middle ? Thanks
good work Ian, although you have made some work for yourself :D :D
hahaha it is confusing the hell out of everyeone
maybe the guid needs to include how to purchase too
hahaha
yes there are at least 12 people who want this mod in Oz .... christ!!!
so what you actually get is
- motherboard
- screen
- wires
- more wires
- tweeter
- screen protectors
that's it
it's a DIY process. or you can send your cluster to russia.... but that's no fun
hahaha
- motherboard
- screen
- wires
- more wires
- tweeter
- screen protectors
that's it
I would love to do that mod but my fis clocks are the non can ones, i wonder if a can emulator can be used to spoof it, cause the only thing the canbus is used for on the facelift clocks are the radio, everything else is K line. i saw the diagram on the russian site, doesnt look too complicated
Until you see how small those contacts are
COLOUR MFA WRITE UP
TOOLS REQUIRED:
- soldering iron (fine tip if possible)
- solder
- solder wicking
- solder sucker
- flux (pen will do)
- philips head screwdriver
- t10 torx bit
- small pliers
- small side cutters
- tweezers
- pin
- blu-tack
- electrical contact cleaner/isopropyl alcohol
- rotary tool w/cut off disc
- small wire strippers
- double sided foam adhesive tape
- razorblade / scalpel knife
- hot glue gun
DISCLAIMER: this is not for the faint hearted... i suggest you have a spare cluster at the ready, and are able to code it in (or have someone code it in for you) as you are pretty much going to ruin the cluster you are going to be working on. Be careful. Read, re-read, look at your cluster, re-re-read again, compare information to your cluster, ask questions and then go ahead and start the job to make sure this is a successful mod. Good luck - it'll be worth it!
STEP 1:
Remove your cluster
Careful not to scratch up the steering wheel column surround - if you do, oh well! That black "matte coating" can be alcohol rubbed off anyway! lol
STEP 2:
Strip your cluster. watch this
up until 3:05. you want to get to the stage where dial faces and needles are off and you can see the white plastic frame underneath.
 06
Here's where the ruining of your old unit begins. Using your side cutters - cut the two "arms" that join the two side displays to the main white frame. Make two cuts (4 in total) - one at each join - you are making a "channel" for wiring to run through.
 07
STEP 3:
remove the white frame (press the tabs from behind). You will get to this point (pic below) - we are going to remove this screen altogether. If you still have the OEM one you will have a blue ribbon which is going to be much easier to remove than this aftermarket screen.
IMG 2091
STEP 4:
Using your soldering iron (or small heat gun) along with some flux and solder wicking - remove the old LCD screen by soaking up the old solder then heating up the contacts and pulling GENTLY to remove the original ribbon from the board.
You can see i heavily damaged mine - i guess this is not ideal but it doesn't matter anyway, you don't need these contacts anymore so don't feel too bad if you end up lifting the tracks.
IMG 2092
STEP 5:
This is what you see after removing the LCD
Flip the board over and focus your attention to these points
 12
These need to be removed. Unsolder the two contact points from the ribbon cable and the two posts arrowed. There is a lot of solder on the two posts so use your sucker to get the majority of it cleaned up. The posts might break off of the board. This is ok. It's going in the bin anyway.
Remove the whole screen housing.
STEP 6:
Underneath are a whole bunch of LED's that used to light up your old, red and yellow, POS display. Remove all LED's using your soldering iron, wicking, sucker, tweezers. (again i lifted one of these traces (oops) but doesn't matter)
 13
STEP 7:
Flip PCB over again. Using your razorblade/scalpel knife you need to make cuts in the track at grey pin 17, 18, 19. Careful not to cut anything else!!!
Screen Shot 2017 02 16 at 083114
STEP 8:
Put the cluster PCB away for now and get back to the white frame.
Make a recess in this little part of the frame. The screen butts up against the top of your cut (depth doesn't matter)
 09
 10
Okay you're done with the white frame for now.
STEP 9:
This is where the fun begins. Using your blu-tack, prop the colour MFA motherboard onto the PCB to mock up your lengths of wire. Wiring diagrams as follows. #1 is always the square contact. Study this diagram and the pin out's carefully. Find them on your board so you can navigate your way around wiring everything up.
A3 ColorMFA rev2017
Screen Shot 2017 02 16 at 075804
(the original setup was for left hand drive cars - i found this out when the door open logo was showing PAX door open when driver's door was open. Follow this pin out setup (not the one on the drive2ru website) - i have already corrected it for RHD cars like ours)
SO in reality the motherboard will sit like so on your cluster PCB
Screen Shot 2017 02 10 at 184705
What i think you will find easiest (which i didn't do) is if you blu-tack the motherboard onto the cluster.
Put the blu-tack onto the points where the screen will be double sided taped on - like so (pic below). Do this so you can mock run the wires appropriately and don't end up sticking the motherboard on with wire under it or cut lengths of wire that are too long/too short.
 15
Get the wiring out and "run" the wires to their relevant contacts adding a centimetre or two to allow for error. They are quite generous with the wiring so don't be scared to use it up. You want the wires going to the blue or green connectors to run down by the tops of the two side displays and then run up to their points.
Ideally to look something similar to this (this is an old revision of the board so don't worry if it looks slightly different to yours.)
 19
STEP 10:
Strip each end of your wires. You only need a little nubbin to be stripped back. I found i couldn't get them through if i tinned them. So i carefully twisted the ends bare, slid them through and then soldered on. Be patient & make clean joins like so (pic below).
I would do this OFF of the cluster PCB so you don't drip excess solder onto places you don't want it. Just solder the wires onto the colour MFA motherboard NOT onto your cluster PCB.
 c04
 c05
 c06
If you mess it up this is where the pin comes hand to be able to separate the contacts from each other.
You don't want this...
 w02
Mock it up - if you've found your wires are too long (like mine) you will need to cut, and re-strip as required. I got gung ho and soldered straight onto the cluster - leaving me a lot of re cutting and re soldering to do.
IMG 2114
alright! End of this step you should have something that looks like this... add the double sided tape to make a thickness of 5 layers of tape at these three points. Careful not to place it directly underneath and of the wires.
 15
STEP 11:
Mock it up again. Ensuring all your wires can reach their necessary pins, while they are routed like so
 19
You can get perfect placement of the board by putting the white frame on top. The motherboard will butt up against the the very bottom of the centre part you cut before (The original outside edge of the frame where it is flat).
Screen Shot 2017 02 16 at 082747
To centre the motherboard you can use the fuel gauge and coolant temp. gauge motor pins as your guide.
STEP 12:
Remove the white frame and solder wires onto the cluster PCB.
The analogue/boost feed wire can be fed through one of the holes near to where the old ribbon was, along with the two speaker wires (just above the blue barcode). The 4 USB wires can routed to where the original LCD's metal bracket was. Through the "slot" (bottom RHS of the pic).
Screen Shot 2017 02 16 at 083926
STEP 13:
Mock up the display and place double sided tape as in the photo. You want to aim for it to sit flush with the rest of the white frame.
 17
STEP 14:
Triple check your soldering and place your speaker in the rear like this.
Green
 19 1
Grey
 19 2
Blue
 19 3
Speaker placement (use hot glue gun)
 20
STEP 15:
Test... take a deep breathe with fingers, toes and pubes crossed. I did this on a bench setup so this brake light notification is normal. In the car it'll kick you to the home screen and you should be able to use your wiper stalk controls to navigate.
STEP 16:
Almost done! You need to put a strip of black tape at the top of the LCD like in the video above (otherwise you will get light leakage to the part under the fuel/coolant gauges).
Secure Colour MFA to the cluster motherboard. Ensure:
- your wires are routed through their "channels"
- no LED's are being blocked by wires (re adjust your soldering if so)
- the white frame clicks home
- the Colour MFA LCD is flush OR under the level of the white frame and is centred
- you seat the Colour MFA LCD all the way home
- secure all your double sided tape points
- put screen protector on Colour MFA LCD
- hot glue gun the USB (i dremeled out that hole) and route your boost feed line like so
IMG 2126
You should have something like this from the front.
 21
STEP 17:
Have a stiff drink.
STEP 18:
Re-assmble your cluster. Ensure you calibrate your needles properly. I like doing this by aligning them to zero. Turn the ignition on and the needles will either awkwardly move to the wrong place or not. If the speedo or tacho moves, turn the car off, remove the needle and place on zero again. Keep trying until you have it right.
STEP 19:
Did i say you were done? Sorry i lied. Time to hook up your boost feed. Get under your bonnet and find your MAP sensor (down behind the left headlight, in front of the battery). We are tapping into wire #4. It's purple with grey (i think???) stripe.
IMG 2129
FullSizeRender
I just stripped it back and soldered the tap (blue wire) and then put it back in it's trunking.
Route your boost tap through the pollen filter/firewall grommet (requires glovebox removal) and to the back of the cluster. I used bullet quick connectors so if needed i can disconnect the boost tap from the cluster easily.
Screen Shot 2017 02 16 at 091354
STEP 20:
Button everything up and ENJOY life in Colour MFA!!!
Reactions: fingermouse, feck_on_a_stick, s3 Hoggy and 7 others
guys please let me know if things in the post don't make sense or needs clarification so i can fix it.
ta.
Reactions: Roadtrain
Even after reading that I'm still ain't got a clue what I'd be doing. Unfortunately I don't think I will be doing this to complicated for me and unless someone over here starts fitting them I don't think il be getting one I took electronics at gcse 3 months in they moved me to woodwork that's how good I was ha
It is daunting. That's for sure. But I'm sure if you took your time. And studies the process to get semi comfortable with it. You would be able to do it
You should've seen what happened on an Audi performance builds group on Facebook. Omg. Still trying to keep up with messages.
This really is impressive tho. Not just the modification which is awesome (OEM+ and SUPER useful), but the write up and step by step is superb. I'm no electrics guy, I would rather rebuild a gearbox with chopsticks than tackle something like this, until I read your guide... I would tackle this for sure
Reactions: IPG
dooo eeeeetttt!!!
Great stuff.
I have a facelift S3, what is stopping me buying a second set of clocks to do this on?
Are the clocks/mileage etc coded to the ECU?
Great stuff.
both clocks and ecu keeps a record of the mileage (you can put clocks in that displays different mileage but the ecu will still record and have the true mileage of the car) you code the key to the clocks, you just need your skc or if u dont have it pull it with vag tacho, there's a guide on the ross tech site if i remember correctly.
@IanPG
I've no words, you're incredible! Anyway, I'm able to do step 17 only, but I really appreciate your abilities and you're sharing here! ;)
PS:
I think this guide need a different dedicated thread too, because it'll should be more easy find it for other users in future :)
Reactions: IPG
Ripper write up mate,well impressed with you're handywork.
Reactions: IPG
absolutely amazing!! i want one! lol.. if only i had a working S3 to slap it into!
spot on write up - was able to follow right off the bat - hats off to you sir!
Funny story.
In the long video where you can see the clocks turn off and then only the central warning lights come on. (@ 39 seconds) Is where I flashed it with the file direct from noggie - it did not like this at all!!! It would start the car, but the speedo,tacho and side display lights didn't work. Lesson learned.
Do NOT use a cluster pull to directly upload to another cluster haha oops.
839
31
6K
90
15K
