No temperature on gauge (dead sensor)?
jcb Mar 26, 2012
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    If it is dead and has been driven like this is that a problem?
    it seems very hot but the 2nd fan isnt kicking in
  2. Bradderz_1988
    3,926
    231
    Whats it reading on the hvac ?? Mine displays 30 every now and then when it drops off and also reads 30'c from cold so presuming its the sensor.
  3. jcb
    4,132
    13
    no reading , needle is unmoved
    (by HVAC I assume you mean gauge?)
  4. Bradderz_1988
    3,926
    231
    No a/c control if you press recirc and the up button for vent distribution then go to 49 then press recirc it will give you the actual temperature in digits.
  5. jcb
    4,132
    13
    they want £33 for a new one!!
    eBay have then for £7. is that a disaster waiting to happen!?
  6. aragorn
    17,962
    702
    yeh i'd stick to genuine, speak to Jason.S on here he'll get you some discount.
  7. jcb
    4,132
    13
    TPS are selling stuff at Audi dealer prices.
  8. Bradderz_1988
    3,926
    231
    Theres meyle ones on ebay for about £9 iirc
  9. jcb
    4,132
    13
    saw those. and some febi ones.
    TBH I do not want this to turn into a money pit
    if the sensor was goosed why would it run hot?
    I assumed it would run cool if anything as I expected the fan to be on permanently.
    Also done a full scan in VAG and no code for ECT sensor....strange?
  10. Bradderz_1988
    3,926
    231
    No code here niether aslong as the stat is working and the viscous fan is running id say your ok the electric fan is there as a back up and when the A/C is switched on iirc
  11. jcb
    4,132
    13
    so its not the sensor or it is the sensor but not an issue to run it like that?
  12. aragorn
    17,962
    702
    Sensor for the fan is totally unrelated to the sensor for the dash.
    The CTS on the back of the head supplies a signal for the guage and a signal for the ECU. If this is faulty you'll have **** economy and probably dodgy emissions as it'll run rich all the time.
    The electric fan is controlled by a 4 pin sensor in the bottom radiator hose, and/or the Aircon controller. The viscous fan should run all the time. If you switch the AC on and the electric fan doesnt start then its faulty/broken/unplugged/blown its fuse...
    Is this the TQS your on about, or something else?
  13. wallace78
    wallace78 Member
    146
    i didnt get a book with my car how do u put the aircon on iv a funny feeling its not working and were abouts is the sensor in the ingine bay,chees
  14. aragorn
    17,962
    702
    Facelift or Prefacelift?
    Facelift runs the AC all the time unless its below 5c or you press the ECON button.
    Prefacelift has a "frost" symbol on the climate unit to turn on the AC.
  15. wallace78
    wallace78 Member
    146
    cheers m8 mines the facelift:icon_thumright:
  16. Bradderz_1988
    3,926
    231
    Yeah i couldnt sus that one when i got it so i make sure the econ button is lit up all the time.
  17. jcb
    4,132
    13
    A6 2.8Q
    but the A6 forum is like a morgue!
    will check the AC
