New brakes needed, what size?
DJM1982 Feb 15, 2011
  1. DJM1982
    DJM1982 Member
    394
    I need new discs and pads on the front on my Audi A4 but not sure what size they are, can anyone help.
    I have asked badger5 and according to the chassis number it comes back with 320mm and 288mm for my car. Can anyone help.
    My car is a 2006 Audi A4 2.0tdi diesel (140bhp), b7 chassis?
    Thanks in advance
  2. aragorn
    18,606
    871
    look in the front of your service book, theres a big sticker with lots of 3 digit codes on it.
    Look for a code that starts "1L?" such as "1LA" and that tells you what size your front brakes are.
    Similarly theres another code starting "1K?" which tells you the size of the rears.
    320mm fronts are either 1LA or 1LC
    288mm fronts are either 1LB or 1LE
    If its different to those post it up.
  3. DJM1982
    DJM1982 Member
    394
    cheers mate, that helps alot. Will did the service book out and have alook.
  4. Ekco163
    Ekco163 New Member
    25
    I've got a code of 1LT on my B7 1.8T which was 312mm Part No: 8E0615301R..... hth
  5. benr
    benr Member
    819
    Yep take a look at eurocarparts. In the details they list the code which is compatible so it will give you the size. Mine are 312 on front
  6. Dazmo
    Dazmo Active Member
    1,762
    I bought mine from here mate. MTEC Brakes, Performace Sport Brake Discs
    Very cheap compared to some websites and if your going to change them you might as well get get drilled/grooved or both, they look better and perfrom better and are almost the same price as the standard discs
