My first vag-com power run the results...... someone?? plz??
cjsuk Jul 12, 2012
  1. cjsuk
    cjsuk Active Member
    567
    80
    Right I did my first logged power run with vagcom tonight.
    I have a 1.8T sport AUM (ko3s) with definned and smoothed box, extra air intake, k&n panel filter and N249 bypass on standard map.
    To me the numbers look to be smooth (if u get me) i'm just worried the mass airflow numbers looks to be low at the top end, please remember I'm un mapped.
    Here's what I did: rolling at 2000 rpm, then foot down untill just over redline, then off the gas, done in third gear.
    Can anyone tell me if my results are: 1. Below Standard (need work) 2. Normal 3. Better than standard.
    Here's the result:
    So is she ok?
    Please remember: I'm now sat like a school kid waiting for exam results lol
    Cheers guys and gals :)
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If it is 150bhp standard thats ok
    if its 180bhp standard its a bit low..
  3. cjsuk
    cjsuk Active Member
    567
    80
    Cheers Dave, its ko3s aum so 150, when U say "ok" do you mean normal for a 150 or can you tell that any of my little mods have made a difference, for instance the air flow, after the mods on the induction i would expect a better figure than standard.
  4. <tuffty/>
    21,560
    4,044
    Your highest airflow reading was 118.75gs so 118.75/0.8 = 148hp (roughly)... looks ok to me based on that... just adding an airfilter to a turbo engine doesn't always net more airflow especially on std cars as they are typically working within the limits of the std hardware.. you only gain if there was a perceivable restriction in the first place
  5. cjsuk
    cjsuk Active Member
    567
    80
    Thanks tuffty So in effect regarding airflow, its like putting 8gb of memory in a 32bit (standard map)windows operating system as it will only use 3gb of the 8gb untill you get a 64bit system (remap)which will use the full 8gb?.
    Am I right in thinking boost looks ok too?
  6. <tuffty/>
    21,560
    4,044
    Intriguing analogy and sadly I understood it lol...
    After a fashion, yes...
    Nogmeister likes this.
  7. Sevv
    Sevv Pushing the limits..
    1,324
    120
    lol same here... sadly got it :p
  8. cjsuk
    cjsuk Active Member
    567
    80
    lol, I thought it was good too! All i'm trying to do is make sure the engine's running optimal and in the best possible condition before I take the remap route (which everything sounds to be ok so far). When money allows I will be fitting a FMIC and Changing all the hoses, tip etc to silicone. All i'm aiming for is 200-220 bhp, is this achievable with what I have or plan to have? What other things would I need to keep the engine and turbo happy and solid. Inbetween the engine side of things I plan coil overs, poly bushes all-round etc, mintex pads and discs (std size).
  9. cjsuk
    cjsuk Active Member
    567
    80
    ha ha, that was the only way I could filter the geeks out lol
  10. <tuffty/>
    21,560
    4,044
    It worked :)
    If you wanted to get really technical you could have mentioned the "/3gb" switch in the boot.ini ;P
  11. cjsuk
    cjsuk Active Member
    567
    80
    <tuffty/> = Been promoted to advanced geek :)
  12. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    Oh god I'm a geek too
  13. cjsuk
    cjsuk Active Member
    567
    80
    Welcome to the geek section of the forum :)
  14. <tuffty/>
    21,560
    4,044
    Just need Welly to pop along... :)
  15. cjsuk
    cjsuk Active Member
    567
    80
    Right as some of you may or may not know I accidentley sort of had my car re-mapped (safe) and after that all the usual boost/vac leaks hit me like a train so now after all that I have sorted pcv delete, boos pipe fixes etc. I thought I would revive this thread with my new updated log :)
    To me all looks good except the bit I highlited on this line it seems there's a blip, I think it could be TB related but ill let you decide also would 203bhp be the right figure i have come to?
    Cheers and here's the results (this is a safe map on a k03s turbo Aum engine).
  16. cjsuk
    cjsuk Active Member
    567
    80
    eh, eh, eh chu!
