Music Car Car Music ummmm
neil stait May 1, 2014
  1. neil stait
    neil stait Member
    59
    13
    Hi everybody
    In June I should receive a shiny new A3 2.0TDI Sportback Sport
    My question is ... How do I get music on to the music system
    I am getting the standard system with the 'reach across the car to change the cd' function
    I also believe the system takes little memory cards of which I know nothing about and don't know how to put music on
    Can anybody help ?
  2. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,681
    522
    Even the basic system has 2 SD card slots. Buy yourself an SD card and you can store hours and hours and hours of music on it. Much easier than loading CDs.
    What format is your music currently in? (CDs? iTunes? etc)
  3. neil stait
    neil stait Member
    59
    13
    I can't work out how to add a ringtone to my I Phone so I tunes is a definite no
    It will be transferring from CD's
  4. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,529
    1,149
    Easiest is to rip your CDs as MP3s and use an SD card as others have said - much better than CDs. I don't think I've yet put a CD into my car! Perhaps I should at some point just to check it works!
  5. 0B1001001
    0B1001001 Well-Known Member Team Monsoon Audi S3
    451
    278
    Don't encourage CD use, stick with a nice SD card chock full of your chosen tunes :thumbsup:
  6. cemerson
    4,529
    1,149
    I have done, trust me, but I'm still going to check the CD player works at some point while I'm still in warranty!
    illingworth22 likes this.
  7. alistairm1
    alistairm1 Active Member
    173
    101
    43
    Not sure how much you know about ripping CDs, so apologies if you know this.
    You can use Windows Media Player to rip a CD down to MP3 files. You can adjust the bitrate (quality) when you rip the CD.
    Use the best rate you can to ensure the quality of the MP3 file is suitable. The usual advice is use the top rate available. In my (old) version of WMP the top value is 192.
    You will then have a number of MP3 files. These should be organised into a folder. The folder hierarchy I have seen recommended is Artist>Album, so a folder called U2 will have a folder inside it called Joshua Tree, and that folder will have the MP3 files in it. You can add more Album folders into the U2 folder, or create a new folder for a different artist.
    You will need a card reader plugged in to your computer or laptop (or this may be built in).
    Insert the SD card (Max capacity 64Gb) into the card reader and then use Explorer to copy the U2 folder to the SD card.
    Once the copy is complete, remove the card from your reader, insert in your car, and select Media in the MMI.
    Select the relevant SD card, and your music, or whatever, will be displayed.
    There are other threads on here which go into the format of the folder heirarchy in more detail.
    I have Four top-level folders (Drama; Comedy: Music; Musicals). Under each of these are folders for Album, or Title (Drama & Comedy), or Show (Musicals)
    So I have Comedy> Cabin Pressure> S1 and the individual episodes in the S1 folder. Works for me but you may prefer another structure.
    There are instructions on how to navigate the folders through the MMI included with the car.
    Note: Only picked U2 as it was less typing. :sm4:
    Jeff777LUFC likes this.
  8. cemerson
    4,529
    1,149
  9. 0B1001001
    451
    278
    One thing to note is that the MMI does not understand the "discnumber" tag, so if you have a CD consisting of multiple discs tagged 1,2, etc., I'd number the tracks 01-XX starting at disc 1 to ensure they play in the correct order. Lazy MMI programmers! I'm just copying my compilation albums back to SD card after editing to test this works OK now but it's going to take a while...
  10. neil stait
    neil stait Member
    59
    13
    Here you go......... good idea coming up Audi
    Why don't you install a cd player that rips the music straight to the memory card underneath
    Dragon's Den here I come
    RYuill likes this.
  11. mjcourtney
    1,681
    522
  12. 0B1001001
    451
    278
    Most people do that at home instead, rather than in the car! All you need to do then is fill up the storage of your choice and plug it in!
  13. 0B1001001
    451
    278
    That's fixed that, now if only they also understood the album artist tag as well - album cover flow is all over the shop, so I browse via folder structure instead.
  14. neil stait
    neil stait Member
    59
    13
    Another question why do people feel the need to use !!!!!!!
  15. 0B1001001
    451
    278
    Why use album artist tag?
  16. PhatGit
    PhatGit Active Member
    126
    56
    What functionallity does the basic MMI offer from a SD card? (S3 due build week 31).
    My current TT has no SD slot, so I use an old iPod classic. But it can only handle 5 playlists of up to 99 tracks each. My previous VW could handle the full 30Gb on the iPod and any of the functions/options on it. I used to use random album, and really miss that. An option on SD?
    Ta
    Alan
  17. cemerson
    4,529
    1,149
    Several cars do this already, possibly even the A3 does (it has a 'Jukebox' but I don't know if you can source music from a CD for it)
  18. cemerson
    4,529
    1,149
    I don't understand what this is saying?
  19. Jerodequin
    Jerodequin Member
    109
    9
    What is the best file layout for MMI? (i.e. does it work best if you just have a whole bunch of tagged files in the root of the card or does it support folders etc?)
  20. alistairm1
    173
    101
    43
    see #7 and #8 above
  21. neil stait
    neil stait Member
    59
    13
    Sorry just a pet hate of mine being talked down to with exclamation marks
  22. Jerodequin
    Jerodequin Member
    109
    9
    Thanks, not sure how I missed those when reading through the thread originally! :keule:
  23. alistairm1
    173
    101
    43
    no problem. I've done the same in the past.
  24. phil1824
    phil1824 Active Member Team Daytona Audi A3 Audi Cabriolet Owner Group
    379
    104
    43
    This 64 gig memory card was recommended in another part of the forum and appears to be great value.
    I have bought two, but have not tried in the Audi yet as BW is 24!!
    http://www.amazon.co.uk/dp/B007PYBQKC
  25. 0B1001001
    451
    278
    Not sure I follow - who was talking down to you? Just trying to offer help(!).
  26. balsaq
    balsaq Member
    89
    37
    Hope I'm not hijacking this thread. But I've got another question (sort of) related to this.
    Since changing my mp3s to flacs, the size of my collection is well above any available sd card. Has anyone hooked up an solid state drive (or normal hard disk for that matter) and played flacs successfully? Is there a difference with file type support between tech pack and without?
  27. 0B1001001
    451
    278
    I've got three copies of my music now (it's getting silly) - FLAC for Sonos, MP3 for iTunes (just sync'ing to phone) and MP3 for car (due to lack of discnumber support). AFAIK tech pack supports FLAC but as you say, the storage requirement are quite a lot more than MP3, and with VBR MP3 320Kbps, I don't think you'd be able to tell the difference in a car... my advice would be go with a large enough SD and high bitrate MP3 rather than FLAC. I know it doesn't directly answer your questions - sorry :)
    BTW Freac is awesome at transcoding stuff - it did all my FLAC to MP3 conversions flawlessly.
  28. rozel
    rozel Member
    91
    15
    CD's sound much better than mp3's. So why are we downgrading? Is it just for convenience or does the MMI downgrade the sound somehow? To my ears CD playback is so much better through my non-tech pack MMI using the standard Audi sound system than via any other method.
  29. balsaq
    balsaq Member
    89
    37
    That's why I'm trying to keep to flac (plus i've got a lot and cant be bothered to transcode them all, and seems a shame not to use flac with B&O)
    Thanks for the info 0B1001001. What do you mean by flacs not having discnumber support?
    It would be great to hear if anyone has successfully played flacs from an external hd connected directly to the car (not sd or via ipod/smartphone etc)
  30. rozel
    rozel Member
    91
    15
    From what I understand if you have the tech pack then maybe but if not then I don't think so.
  31. Stephen C
    Stephen C Active Member
    259
    37
    Compilations, or other kinds of albums where you have multiple artists within the album. Otherwise the album will show up under each of the artists in the album.
  32. 0B1001001
    451
    278
    I know that, I was asking if they were asking why I use the artist tag :)
  33. Pickle1970
    Pickle1970 Active Member
    243
    157
    43
    This all sounds extremely complicated, i think i'll just plug my ipod in and play them from that
  34. Soulboy
    Soulboy Well-Known Member
    442
    557
    93
    If you can use iTunes - then you should find using the SD card very simple.
    Try this if you are on Windows (from memory.......sorry if wrong):
    Get an SD/memory card and put it in the SD slot on your computer.
    Click 'start' on Windows - then 'music'
    When your music appears, select the folder(s) you want, right click and select 'copy'
    Now press 'start' and 'computer'
    Select the drive with the memory card showing. On the right window, right click and 'paste'.
    The folders should now appear. That's it.
    If it works, your music is now saved to the card. Plug it in your car and away you go.
  35. Pickle1970
    243
    157
    43
    Ahhhh cool, that does sound easy. Thanks
