Mileage versus Engine work done
Molnboman Nov 24, 2013
  1. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Probably has been done to death this one....but am bored...hahaha
    Curious as to know what sort of mileage you have, versus work done over and above normal service ( belts, oil etc ). Extra points clearly go to highest miles still on original main bits without engines blowing up etc etc.
    Shall I start.... my 2.0t petrol FWD, BGB Engine currently on 219,800 kms = (136018 Miles ), still on original clutch, turbo, top end etc. Changed dv, pcv, thermostat, cam follower and that's about it.
    What you got?.....Make sure you comment what engine Model you have petrol, diesel engine model if known.
    A
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    b8 18T 133k
    nothing done except belts tyres discs and pads
  3. Craig Cull
    Craig Cull Well-Known Member
    2,294
    1,027
    Still had original clutch at 100k, did the cambelt just to be sure at 88k, did the cam chain and tensioner at 95k as it was noisy. Coil packs at 77k, diverter at 80k. Other than tyres and brake pads, not really done much else serious in 3 years of ownership.
  4. Paul B7
    Paul B7 Active Member
    622
    34
    2005 2.0tdi ............
    A/C Compressor replaced at 45,000miles
    Front Discs replaced at 56,000 miles
    Oil Pump /Balance Shaft/Water pump and Timing belt Kit at 68,000 miles
    Turbo replaced at 88,000 miles
    EGR Valve replaced at 93,00 miles
    A/C Compressor replaced again at 95,000 miles
    Rear Discs replaced at 98,000 miles
    Original clutch and DMF still going at near the 100K mark.
    This is the most expensive Audi I have ever owned and I have been driving Audi for thirty years. Its also the first and last diesel I will have.
  5. Molnboman
    1,338
    193
    Jaysus, Paul that's a lot of bits Mate?!!.....am interested to see how the petrols compare to diesels .....clearly, there will be a few expensive reports from some am guessing.
    Interesting point that I also have been through two sets of discs since May 2012 myself....
    A
  6. Paul B7
    622
    34
    Petrol for me next time as well.
  7. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,809
    1,463
    I have 2.0T FSI FWD. Done 38k miles. I've done routine servicing, cambelt and tyres so far. That's it.
  8. scotty76
    2,809
    1,463
    Ooops, missed one thing. DV was changed at the same time as Shark remap.
  9. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    A4 3.0TDi
    • PAS pump replaced @ ~60k miles (under warranty).
    • NSF wheel bearing replaced @ ~60k miles (under warranty).
    • NSF wheel bearing + housing replaced @ ~75k miles.
  10. Chr1sch
    Chr1sch Member
    89
    2007 (56) Avant 2.0T Quattro (Special Ed)
    109k
    Cambelt @ 83k
    PCV & Rocker Gasket @ 83k
    New Coils @ 83k - never had them done under warranty!? (free 6yrs later - happy days)
    New Clutch last thursday on 108k
    Very reliable and a great car :)
    Incredibly reliable cars (its had a few wheel bearings with the previous owner)
  11. Chr1sch
    Chr1sch Member
    89
    to add - i do oil and filter every 10k to be safe....
  12. Cyrix
    Cyrix Member
    292
    23
    2007 TDI 170 Quattro.
    4x Injectors + Loom
    DMF + Clutch
    Oilpump/Balance shaft
    EGR Cooler
    Pretty bad for a 64,000 mile car, all work was done by the previous owner though except the EGR cooler. To be honest it was the main reason I bought the car.
  13. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,319
    766
    2008 B7 A4 2.0TDI 109K
    DMF
    Oil cooler
    Expansion bottle and system flush
    Cambelt
    Battery
    Oil level sensor
    Air flow meter
    Dealer serviced as per service schedules.
  14. Molnboman
    1,338
    193
    Me too every 10k - 12 km's for me...emotive subject on the Forum I know, but cheaper than a tank of gas.
    BR
    A
  15. scotty76
    2,809
    1,463
    10k miles is about 18-20 months for me. When should you change the oil if you are doing low mileage?
  16. scotty76
    2,809
    1,463
    Sorry, forgot to qualify that. My mileage is A road + motorway, not short journeys. I'm aware if you are doing lots of stop start then a different regime might apply.
  17. Matt10160
    Matt10160 Active Member
    205
    29
    2005 2.0tdi 92,000 miles
    injector recall 30,000 miles
    10k interval services
    cambelt, tensioners and water pump 85,000
    (Thats all the history of engine work i can find)
    still running strong, touch wood no issues yet
    i can see other things done but its all part numbers so not sure if anything else has been done
  18. Molnboman
    1,338
    193
    Matt what engine code are you running out of curiosity?
    BR
    A
  19. lynallbel
    lynallbel Active Member
    395
    I would say annually gives someone a chance to look under the car as well.
  20. Chr1sch
    Chr1sch Member
    89
    I do 30k motorway miles a yr, but service every 10k, it makes such a difference, engine is smooth and starts/runs like a dream for mileage - amazed to see that the petrols appear to be more reliable than the diesels!
    chasdrury likes this.
  21. Paul B7
    622
    34
    Its really just the 2.0tdi units which are the dogs. The 1.9tdi and the 3.0 tdi units are generally GREAT engines.
  22. Matt10160
    205
    29
    blb
  23. SinghB7
    SinghB7 Active Member
    512
    67
    2007 2.0tdi 140
    158k
    serviced reguarly about every 15k
    new glow plugs @ 153k
    oil pump upgraded in the past
    multitronic gearbox oil changed at 75k
    thats all, eveything else all original and runs perfect.
  24. Molnboman
    1,338
    193
    Scotty, that's a very emotive question that. If your mileage is mostly motorway, than stop start city stuff, I personally wouldn't have it in my car more than 12 months max'. I would change mine every six month max, no matter what the milage was. Now I know I will get pelters for that from other Forum Members, but I have always done this without fail on most cars I have owned with turbos, diesel and petrol. I don't use VAG long life either just the best fully synth 5 40 ( am in Sweden remember ) my garage has at the time Castrol, Mobil etc...and change the filter always.
    Just can't imagine leaving oil in my engine for more than 12 months ( longlife or not )....and the cost of oil and filter change is less than a full tank of petrol. Not sure if it's psychological or not, but I always feel that car sounds and drives better with fresh juice in there.
    A
  25. lynallbel
    395
    Im probably repeating myself here!, but ive always said oil cheap engines expensive.
    Molnboman likes this.
  26. sidibear
    2,319
    766
    110k another DMF
  27. Luke2.0tdi2010
    Luke2.0tdi2010 Active Member
    286
    49
    '06 A4 2.0tdi (BRE)
    around 138,000 miles
    Cam belt + Tensioners
    Water Pump
    Disks/Pads all round
    Oil level Sensor
    EGR Valve
    Clutch switch
    Tyres
    Rear ashtray cover!!
    Apart from a bit of a rough idle and kind of ticking noise whist idling the car runs like a dream, I love it and would never have any other car other than an audi again!
    I'm considering replacing clutch and flywheel, don't really need to but I do get quite a bad judder if I really floor it in 1st. If driven 'normally' it's fine.
    Totally agree with Molnboman, I regularly service the car (every 6k) changing ALL filters (Air, Fuel, Pollen, Oil) each time. Oil is the blood of the engine and the fresher/cleaner the oil, surely the better? For the price of an oil filter - £7, sump nut - £0.50, and 4L of oil - £29.99 (Castrol Edge from costco!) it's a very small price to pay to keep your engine a 'happy one'......IMO
    P.S. I've never changed the power steering fluid.... Should I? and what would be the symptoms of me needing to?
  28. lynallbel
    395
    Ive never really bothered to do a whole oil change on any car pas system ive owned, but if using a vac tool to do the engine oil change its just as easy to stick the nozzle in the pas reservoir and empty it, refill with fresh atf.
    We change every other fluid at set intervals on the trucks but never the pas atf, but the filter is done every 2 years.
    Check the cars atf spec as some motors run some funny old stuff and it may not mix with std atf
  29. A4B8Sline
    A4B8Sline Active Member
    211
    30
    Mine- 2009 A4 B8 Avant 2.0tfsi 211hp.
    43k new clutch and flywheel under warranty. Juddering when pulling away.
    53k rust repairs under warranty.
    65k more rust repairs under warranty.
    70k complete engine rebuild due to oil consumption parts replaced big end pistons rings etc. Also water pump and cam chain changed while this was carried out. Head is original along with the turbo. Costly to me but 70% covered by audi.
    Tyres brakes etc changed when required. I will run the car upto at least 100k and make a judgement on if it's worth keeping depending on further work required between now 77k and 100k. Great car slightly disappointed by big repairs encountered. Would like to say audi dealer has been fairly good with warranty issues when in and out of warranty.
  30. rizzini7
    rizzini7 Active Member VCDS Map User
    951
    146
    43
    Right, not all engine related.
    2005 3.2fsi 97k had 2.5 years:
    Oil every 6 months
    2 sets of spark plugs
    2 sets of tyres
    Front and rear discs and pads
    Brake hoses
    Both top chain tensioners
    Battery
    Cam adjustment valve
    Aux. belt
    Electric fan
    DMF and clutch
    Clutch switch
    Thermostat
    Temp sensor
    2 Coolant
    2 gearbox pinion bearings replaced along with gearbox seals
    2 gearbox oil
    Rear diff oil
    MAP sensor
    Coil packs
    Oil pump
    Driver adaptive xenon
    Both xenon bulbs
    Intakes removed and valves decarboned (gaskets and seals replaced)
  31. Paul B7
    622
    34
    If that had been a horse I would have shot it !
  32. rizzini7
    951
    146
    43
    Lol, yeah. It's. Come very close several times
