Make my TDI sound a bit more 'throaty'
Djwoody Apr 16, 2012
  1. Djwoody
    Djwoody Member
    481
    21
    Other than fitting an aftermarket exhaust, is there any way to make my TDi 170 sound a bit more throaty when accelerating?
    I've looked at induction kits but have heard mixed reports.
    Chris
  2. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    Remove the back box and fit a straight through pipe to the tailpipes, a lad has done that on here and it sounds half decent, that was on a PD140.
    I think he's called 'itwasntme1987'.
  3. Ads
    Ads License to drive
    8,230
    613
    He wishes he was born in 1987.
    It's itwasntme187. Apparently he murders people in his spare time.
  4. A1DEYB
    1,682
    43
    Haha i was close, cheers ads.
  5. Ash187
    7,522
    759
  6. c_w
    c_w Well-Known Member
    1,169
    91
    If it's a PD 170 if you do the DPF delete the only box is then the back box and it gives it a turbo spool noise that is quite loud at idle and a bit of a "whoosh" when accelerating. Not loud I suppose, but the last thing I'd want to make a PD diesel is LOUDER :w00t:
  7. Indy
    Indy Member
    119
    I also did the same thing.
    Simply removed the backbox and had a straight pipe welded on with a tip. Sounds real nice under heavy accel and completely normal and quiet when cruising.
    Btw, the turbo whoosh noise is so loud when the engine is cold. Turns so many heads!
    Drop me a PM if you require anymore info!
