Knowing what steering control unit is fitted?
S90GAV Sep 10, 2013
  1. S90GAV
    S90GAV Member
    563
    after regretting selling my B6 A4 I've got another one, but sadly the new one don't have cruise or dis fitted which I'm gonna be retro fitting it, what I was wanting to know is there a way to find out what steering control unit is fitted without removing the wheel to see if my current one is compatible or if I need to order the correct one.
    Gav
  2. madmike01uk
    madmike01uk Member
    430
    21
    if it's the module on top of the column you are on about then the easiest way is to remove the two torx screws and removed the top of the cowl and check.
  3. S90GAV
    S90GAV Member
    563
    It's the u shape one, I'll have a look tonight cheers
  4. S90GAV
    S90GAV Member
    563
    I had a look, turns out I need a different controller :-(
  5. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    Which one do you have?
  6. S90GAV
    S90GAV Member
    563
    Part number ending in S which isn't dis or cruise compatible
  7. AudiLeon
    2,202
    160
    Sadly so. I hope this list might help you find the right one.
    Lowline
    • Supported Steering Wheels: Standard Steering Wheel (4-Spoke)
    • Supported Features: Trip Computer (does NOT support Cruise Control!)
    • Part Numbers: 8E0-953-549-F 8E0-953-549-S
    Midline
    • Supported Steering Wheels: Standard Steering Wheel (4-Spoke), Sport Steering Wheel (3-Spoke), Multi-Function Steering Wheel
    • Supported Features: Trip Computer, Cruise Control
    • Part Numbers: 8E0-953-549-L, 8E0-953-549-N
    Highline
    • Supported Features: Trip Computer, Cruise Control, Steering Wheel Heating
    • Part Numbers: 8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R
  8. S90GAV
    S90GAV Member
    563
    I've managed to get a controller on eBay complete with cruise stalk, dis stalk and indicator stalk for £69
  9. madmike01uk
    madmike01uk Member
    430
    21
    Jammy sod, I'm after cruise but mine isn't compatible, looked on ebay but gave up :-(
  10. S90GAV
    S90GAV Member
    563
    it came today :)
  11. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    Thread revival here
    So in theory if my car has cruise control as standard all I need to do is fit the wiper arm with controls for DIS as my module should already support it?
    I know the coding will need changing, but I have vag-com so that isn't an issue.
  12. AudiLeon
    2,202
    160
    Yep It would have to be an L or N min.
  13. hades-
    9,481
    646
    yes if you have cruise dis is plug an code
  14. Jimmy TDI
    1,320
    262
    Cheers guys I'll have a look for a stalk on eBay, breakers, etc at work why I'm on nights tonight then.
  15. Jimmy TDI
    1,320
    262
    Revisiting this as I have bought a new steering wheel, so would rather fit a DIS stalk at the same time.
    Does anybody know if the stalk from a B7 Avant would work?
  16. hades-
    9,481
    646
    If you have a b6 b7 it will work
  17. Jimmy TDI
    1,320
    262
    That's good then as I've found a B7 stalk for half the price of a B6 one.
    Cheers for that :beerchug:
  18. sabaxter
    sabaxter Active Member
    465
    27
    Jim how do you fancy coding my Cruise Control once I have fitted all the components. I'm happy to give you a few quid mate. Is the DIS just the wiper stalk with the rocker switch on the end or am I mistaken?
