Key fob problem
TURBOTRONICS
Iv only had my 03 s4 avant since the weekend and Im having problems with the key fob
When I lock the car and walk away the ****** key fob suddenly starts transmitting the unlock signal continually so the doors unlock and the windows come down
I have to keep pressing the open button till the light stops flashing
Then press and hold close button till all the windows are shut
THEN run like hell out of range of the car so the ****** windows don’t come down again
Has any one else encountered this problem?
Im assuming I need a new key fob so can any one tell me where I can get a new one from without going to Audi them selves and paying fortune?
Any advice is gratefully received
Hi you can get a key off e-bay for arround £25 and then get it cut and programed £30 you will need to know your skc code it normally on a plastic tag you get with the keys to your car and also make sure you get the right frequency fob for your car!
The problem is with the remote not the blade and chip . If you have a rummage around your remote you may find a reason for the sticky unlock button.
For the time being why not just use the key in the drivers door lock to lock the car rather than a Basil Fawlty impression?
if i take the battery out the fob while i strip it down will it affect the programming its the only key and if it stops working im stuffed
The key splits leaving the remote separate, the transponder chip remains in the blade part. You can safely work on the remote , like you would if say the remote battery needed changing .
iv been looking on ebay for a new key fob only i dont know which is the right one
im unsure how to check which is the correct part number
the only number i can fined dose not match up with any numbers on ebay
686
923
573
