Indicator Lights stopped flashing
boson Jul 6, 2009
  1. boson
    boson New Member
    26
    I have an A3 2000 1.8 sport model and having a problem with my indicators.
    Whenever I go to indicate left or right both the indicator light on the dashboard and on the outside are lit but dont flash.
    I've tried turning on the hazard lights and these still work fine.
    Can anyone help?
  2. Andy_S3
    Andy_S3 Member
    722
    Could be the relay, think if you buy a new hazard light switch it fixes the problem, happened on a friends TT.
  3. AlexStanley
    AlexStanley Member
    621
    I had to change the relay on my A3 (1999 1.8T) as the indicators were flashing, then not, then all over the place.
    It's an all-in-one unit along with the hazard warning switch - not too difficult to replace, and from memory about 30-35 quid from an Audi dealer :)
    I reckon that will do the trick!
  4. boson
    boson New Member
    26
    Thanks,
    would this do the trick?
    http://cgi.ebay.co.uk/VW-AUDI-INDIC...66:2|39:1|72:1683|240:1318|301:1|293:1|294:50
    im not 100 % sure the name of the part to search for
  5. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Don't think that's the right part mate at least I know it's not the right part for an s3 and I presume it's the same part you will need, they cost about £35, quite an easy fix just a bit of a pig to get it out!
  6. AlexStanley
    AlexStanley Member
    621
    No it's not the right part - the part for the A3 has the hazard button as part of it, so you'll see the red triangle on one side of the relay.
    Best bet is to go to Audi and get them to look up your car on their system - there are at least 2 variants of the relay so at least you know you'll get the right one with them! (That's what I did anyway).
  7. Nilz
    11,319
    872
    Thats the wrong relay, you need the whole unit, which integrates the hazard switch as well, it cost me £35.91 a couple of weeks ago and its a dealer part only, fitted it myself, its a bit difficult to get to grips with it, but it can be done, just be careful if you are taking the stereo surround out, not to scratch anything.
  8. boson
    boson New Member
    26
    the indicator started working again this morning, which makes me think it's fixable? do you think it is? as it's likely to probably stop again
  9. Andy_S3
    Andy_S3 Member
    722
    I think its an intermittent fault, so chances are it will start playing up again. But give it a couple of days & see what happens before going to Audi for a new part.
  10. s3 Hoggy
    1,716
    158
    I'm sure it will come back mate as mine did this, your probably best just buying a new part and fitting it, as it's not particulaly safe having no indicators both for you and other drivers/cyclists, as said before only £35 easy fix,
    Cheers matt
  11. Nilz
    11,319
    872
    They will go again, mine went and then i finished early to get the part and fit it and all the way to Audi it worked, until i pulled into the car park, now hows that for timing!!!
    I was even going to contemplate leaving it, but good job i didnt, i do alot of motorway driving so was imperative that i have a car in full working order at all times.
    For the sake of £35 and 30mins work, just get it done, sods law is it wil go when you need them and could even land you in trouble.
  12. Effect
    Effect Member
    469
    I can sell you a brand new unused one
    I bought it to fix a problem I was having but it didnt cure it as it turned out to be an entirely different problem
    £20 + p&p and its yours bud.
  13. s3 Hoggy
    1,716
    158
    Bargain take it off his hands!
  14. boson
    boson New Member
    26
    how much you want for postage? would you accept paypal?
