If i change cluster will the miles be correct
billybaggins May 26, 2013
  1. billybaggins
    billybaggins New Member
    23
    As above, my lcd is fooked, if i put a new cluster in will it read my miles still from the ecu or will it show the donor cars mileage? Cheers
  2. aragorn
    18,135
    764
    The mileage is stored in the cluster, not the ECU.
    You can fix the difference with a Vagtacho interface.
  3. jbh
    jbh TDi lover
    1,398
    162
    are the clusters coded to the key?
  4. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    you will need the SKC for new cluster and to code it with vcds. If you dont have it,it can be retrieved with vagtacho or similar.
