Idle control valve
MOSSY Apr 28, 2006
  1. MOSSY
    MOSSY Member
    93
    Does anyone know where it is on the S3???? I want to check it and give it a clean out.
  2. HTC
    HTC Active Member
    3,428
    9
    There is no separate idle control valve to speak of. The idle is controlled by the electrobic throttle body.
  3. MOSSY
    MOSSY Member
    93
    Thanks, I thought it would have had a seperate one.
    I wanted to clean it out because of the problem i am having with startup. (car is nearly cutting out when I come to start it first thing in the morn)
  4. HTC
    HTC Active Member
    3,428
    9
    I would check to see if you have the updated coolant temp sender. This would be my first port of call.
  5. MOSSY
    MOSSY Member
    93
    HTC,
    How do I check for that???
    Car is 2001
    210 BHP
  6. HTC
    HTC Active Member
    3,428
    9
