Ibiza MK3 Brembo calipers on S3
Andyrew_69 Sep 12, 2012
  1. Andyrew_69
    Andyrew_69 Member
    Hi there got chance of a set of Ibiza MK 3 Brembo calipers for an upgrade to my standard s3 set up. Car is going to be running approx 350bhp when finally get round to doing it!
    Just wondering.....
    A) do these fit straight on and if not what will i need to fit them, adapters/discs etc??
    B) is it a worthwhile upgrade for the power??
  2. <tuffty/>
    21,359
    3,926
    Mk3 Ibiza Cupra uses Brembo Jnr calipers IIRC... they are designed for 304mm discs... Bill knows all about these calipers as he sells new calipers with his brake kits... I know he also sells the braided hoses, pads and brackets to use LCR 323mm disks
    Mk4 Ibiza use AP Racing calipers and 312mm disks... (edited as I got it a little round my neck!!)
  3. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    do you know what the piston sizes are in the jnr kit?
  4. jojo
    28,907
    3,563
    I'd go with the LCR setup myself personally, we all know it works and bolts straight on.
  5. Alex C
    3,267
    360
    that what i was thinking. If the jnr kit shares the same pistons sizes as the LCR brembos but only sit on a 312mm disk then i think its a down grade from the standard S3 setup with respect to braking force
    unless of course you got a custom bracket and fitted them onto 323mm disks
  6. badger5
    9,507
    2,003
    ibiza cupra r brembos are GT Juniors.. and will work with 28mm thick disks... So.. options are 323x28 disk, bracket to suit your hubs and these + hoses, pads etc.. and you will end up with an equivalent of a Brembo GT Junior kit
    I have brackets, hoses, pads, and disks to suit these calipers.
    you will NEED 50mm Caliper clearance on your wheels to clear the caliper to spokes.. as per this piccy> [​IMG]
  7. badger5
    9,507
    2,003
    they dont, they sit with 323mm disks for 5x100 fitment, and 304x28 on ibiza fitment.. Not 312mm
  8. badger5
    9,507
    2,003
    so do these....
  9. Andyrew_69
    Andyrew_69 Member
    So compared to standard s3 brake set up are these a worthwhile upgrade or not whats your thoughts?? cheers
  10. badger5
    9,507
    2,003
    yes
  11. Andyrew_69
    Andyrew_69 Member
    lets say then i have the calipers, i have pads, how much for the brackets and hoses?? oh and i'll need some discs....what discs do you use?? i am running 5x100
  12. badger5
    9,507
    2,003
    brackets are £75 each, hoses £47.50, disks from £122/pair for EBC plain, of +£50 for eliptically grooved versions or £117/Each for Brembo plain disks
    all +vat & UK Delivery
  13. Andyrew_69
    Andyrew_69 Member
  14. Andyrew_69
    Andyrew_69 Member
    what car do these discs originate from??
    also if i was to source a LCR brembo set up would that bolt straight on or would i need brackets also??
    thanks
  15. <tuffty/>
    21,359
    3,926
    Prices are there dude....
  16. badger5
    9,507
    2,003
    Brembo GT kiy are 323x28
    LCR also use same size disk as OE... and prices I have already posted
  17. badger5
    9,507
    2,003
    if you bought a "COMPLETE" LCR brake setup then it would just bolt on yes, but it would include the caliper mounting brackets, and wheel spoke clearance comment is the same
