I was considering a rear wiper delete but...
y2kcurran Nov 11, 2013
  1. y2kcurran
    y2kcurran Member
    127
    24
    I really like the blanked off look a the back, I had it done to my Mk4 Golf and never missed the wiper. However does anyone else find that the A3 (I have 8P) creates a whole lot of spray on wet/damp roads? I find that even after a good wash the front/sides stays relatively clean depending on conditions but that the rear becomes boggin even in just damp. Has anyone done the delete that could share whether they miss being able to clean the back window when needed?
    Thanks.
  2. autolatry
    autolatry Active Member
    347
    67
    Tint the rear. Mine is so dark i cant see out of it anyway so it wouldnt matter if it was clean or not.
  3. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Can always dewiper then put a rain repelent on the window such as RainX or similar.
    Sidhu88 likes this.
  4. Keane
    Keane Active Member
    474
    66
    Has too be done !! Looks soo much better 👍
  5. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    i have rain X on my back window, i still manually use my rear wiper,
    and yes SOO MUCH SPRAY gets on mine, i dont even know how it gets under the spoiler BUT IT DOES
  6. leeds2592
    1,399
    222
    Loads of products out there that are better than RainX but just suggested that as it's readily available and easy to apply but may not be the best if you still have to use your wiper.
  7. JJ.Foulds
    1,263
    176
    i still have to use my wiper caus of the spray, my front screen with rain X works great, dont even need wipers on after 50mph with rain. but my back gets soo dirty its unreal, im not sure if its caus i dont have sline bumper or anything like that :/
  8. Artimus
    Artimus Shortback
    2,017
    485
    I expect it's a combination of the tyres lifting the sh*t off the road, along with the shape of fat the rear end creating a low pressure zone, commonly known as Drag. :blink:
  9. jphc
    jphc RS6 Dreamin'
    163
    9
    Am i the only one here that thinks removing the rear wiper is a rather silly idea?
    samnewman and grainqey like this.
  10. N4th4n90
    N4th4n90 Member
    52
    10
    Removed mine as it stopped working, regularly use Rainx but still gets dirty pretty quick, don't miss the wiper though
  11. Jason-3.2
    Jason-3.2 Member
    222
    I like my rear wiper, when mine packed up I replaced it in double quick time. Driving home at 2 in the morning on the motorway I don't spare the horses and I like to know who's following !
    samnewman, Toomanycars007 and wuta3 like this.
  12. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    610
    Dewiper - the rear of the car looks so much better without it - done it with my last 2 A3/S3 :)
  13. Mindak
    Mindak Active Member
    803
    130
    43
    Is this easily done? Iv had my a3 since Thursday and it's doing my head in already especially when it automatically comes on when reversing! Lol
  14. BradV6
    BradV6 Member
    84
    When my wiper motor packed up i replaced the arm with one from a mk5 golf, looks loads better and gives a stubby appearance
  15. DeckedS3
    DeckedS3 Well-Known Member
    878
    301
    I'm with you on that!
    jphc likes this.
  16. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    Likewise. There's nothing worse than not being able to see much out of the rear window!
    jphc likes this.
  17. J8TT X
    J8TT X Member
    360
    9
    Was everything the same apart from the actual wiper arm?
    My wiper has snapped so looking to replace the whole arm.
    Just looked and Mk5 arms are cheaper than the normal A3 ones..
  18. pwilliamson1991
    pwilliamson1991 Member
    77
  19. BradV6
    BradV6 Member
    84
    Well I went to a scrappy and found a perfect condition wiper motor in an estate mk4 golf for £25 quid (the guy was aware of the common problem so that was his price) and the wiper arm was of course from the mk5 golf. All fits and works fine and had no problems. Can get a pic up if anyone needs it.
  20. Muzza80
    Muzza80 Well-Known Member
    700
    337
    Nope you're not, why the hell would you want to remove the rear wiper on any car?? It's there for a bloody reason lol
    jphc and Phil-1 like this.
  21. y2kcurran
    y2kcurran Member
    127
    24
    Thanks for all the replies! The removal is purely for aesthetic reasons, I just like the blanked off look alot. I'd have taken it off when I first got the car but I began to realise that it was coming in pretty handy quite often as like I said I noticed that the back window was rarely ever clean! So i'm trying to balance functionality with vanity at the minute lol, the water jets arn't working either so if I can fix those easily it will probably stay (for winter anyway!). Otherwise I'll get a ball joint separator (thanks for the advice PW), take it off and get some RainX or something similar and see how that goes for a while.
    Cheers again for the advice/opinions.
  22. DeckedS3
    878
    301
    Just try rainx now and don't wipe it.... I've got rainx on my rear window but I still use the wiper regularly. It's particularly bad on the roads at the moment as they've started to grit them and it kicks up **** from about 45mph. After 5 miles on the motorway in the wet you can't see much detail through the rear window without a wipe.
  23. immo
    immo Stop me
    275
    40
    It would be like driving a van!! No thanks
  24. Sidhu88
    Sidhu88 Active Member
    808
    76
    Rear wiper never worked on mine so i've never missed it. I do have issues with standing water and rearview vision if i haven't cleaned the car in a while but i use rain-x so seeing through rain is no issue and for everything else i keep glass cleaner and some microfibres in the boot. I rarely find myself having to clean it though, saying that my car gets a clean weekly with rain-x applications after each clean
  25. Ash187
    7,505
    748
    I always use the rear wiper... Prob an OCD thing but I don't like any marks or **** on the rear window. When I use the rear window washer I watch the rear for drips and try to catch them so my rear window is clean! Lol
  26. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    How do you cope with the nice clean arch where the wiper is but dirty and wet rest of the window? :)
    I don't think a rear wiper is really needed.
    If you keep the car clean and your rear heater work you'll be ok.
    Vans, trucks and saloons do ok with no rear wiper. :thumbsup:
  27. Ash187
    7,505
    748
    Like this?
    Im fine with that
    Artimus, immo, nezz and 1 other person like this.
  28. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    Hmmmmm totally disagree with you there Scott. If you live in a city and do an average of 20mph then yes I can see no need for a rear wiper. You've been to where I live mate and in this weather if you didnt have a rear wiper it would be impossible for you to view anything out of the back window..........countryside = fields = ignorant farmers that trail half the field onto the road.
    immo likes this.
  29. ScottD3
    15,164
    1,123
    Side mirrors work?
    My rear window was **** high by the time I got to Loch Ness but I gave up using my rear view mirror when I got to the border.
    I've never really relay on my rear view mirror that much. I've spent most of my motoring time in/on vehicles with out them, so not having one never really bothered me.
    Plus good set up side mirrors should be just fine.
    I guess it comes down to what each person is happy with and what they use to.
  30. Brodster
    3,548
    886
    Each to their own buddy. Washed my car yesterday and it lasted all of 5 miles today......its minging now so its impossible to keep clean with the state of the roads as they are. I feel very strongly about imposing fines to those that bring half their fields onto the roads.........and being a biker aswell but bikeless I would hate to be confronted with whats left lying about.
    ScottD3 likes this.
  31. TDI140
    TDI140 Well-Known Member
    1,632
    174
    Mine hangs onto the boot lid proper annoying but useful as i have oil in intercooler until i fit my s3 intercooler, depending on what it actually smokes like i might delete as well. Also mine is tinted dark around the rear windows just one shade lighter than limo i think
  32. Boon
    Boon Active Member
    441
    59
    Never used my rear wiper, don't like the scratch marks it leaves with wiping all that crud across.
    My daily drive is a van with no rear windows so can't say I miss trying to look out of it, when I remember I can see out!
  33. NICKK
    NICKK Member
    31
    Keep the wiper.
  34. CraigWonn8P
    CraigWonn8P New Member
    15
    I'm de-wipered and use rainX with no problems at all. Better than a half working wiper!
  35. S3-MJD
    S3-MJD Member
    58
    might be a stupid question but is there a kit or something that would provide everything to de-wiper, or what would be the procedure for taking it off??
  36. OhSoFresh
    OhSoFresh Member
    95
    If you dewiper does it throw a fault on the dash? Also do you have to use Vagcom to turn off the water shoot lol
  37. Ash187
    7,505
    748
    if you just dewiper then no fault but you should block up the water pipe as an accidental push of the stalk will send water, just deactivate it in VCDS
  38. OhSoFresh
    OhSoFresh Member
    95
    Okay cheers bud
  39. s3_trev
    s3_trev Northern Ireland Gold Supporter Audi S3 Team Brill Red
    1,866
    646
    When you deactivate it in VCDS what exactly does that deactivate? Will the water still come out of you pushed the stalk or does deactivating cure that problem??
  40. Double V
    Double V Member
    91
    So how come on saloons we don't need them ?
