HOWTO: A must do mod - poly dog-bone mount!
SiGainey Feb 2, 2011
  1. Sam_
    Sam_ Down under
    3,035
    480
    Mine's just arrived (Red). Will report back once I've fitted it along with Haldex blue and a new thermostat this weekend.
  2. [Dave B]
    [Dave B] Daddy
    2,027
    145
    You won't believe the improvement it makes to the feel of the car, and for under £20. BARGAIN.
  3. steviet
    steviet Member
    439
    Anyone got a nocking noise after fitting this?..when going over pot holes etc,
  4. Westy
    Westy Well-Known Member
    17,442
    1,100
    No mate. Maybe fitting the mount has highlighted another issue on your car?
  5. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Are all 5 nuts/bolts correctly torqued?
  6. steviet
    steviet Member
    439
    Its a nocking noise when i go over pot hole etc just from the drivers side.im gonna take it off again and torque all the nuts up and try then.im sure it has only started since i fitted it!.
  7. Westy
    17,442
    1,100
    It may have highlighted a weakness somewhere in your suspension. Could be bushes or ball joints.
  8. steviet
    steviet Member
    439
    Nope mate ive done all that,i dont have a arb.i have new wishbones,new top mounts,new bearings etc and new coilovers!..i have just taken out the front coilover and the sharft has play so i put my old ones back in but still have the same problem!.
  9. Westy
    17,442
    1,100
    Hmmm bit strange.
  10. audi-tk
    audi-tk Member
    441
    Got my deisal dog mount I'll post how it is. Will be done with new top mounts , lowered 30+mm more and a TT arb ;)
  11. mrj0ey
    mrj0ey Member
    105
    HEy, I changed my bush to the red diesel one......plus loads of other bits, ball joints, tie arms, full superpro front bush kit etc etc etc and then i got a knocking when pulling off, braking, turning, over bumps etc.....It was driving me MENTAL! Turns out that the rear engine mount is not supposed to be removed that often and being stretch bolts into aluminium they can wreak havoc with the threads in transmission.....Every time i removed the mount to look for the noise and the re torqued the bolts i was stripping a little more thread....it gave way on me last install......drove it to Midland VW and Jody heli-coiled it for me....knock has now gone.
    The middle 16mm bolt was swinging in the threads, causing the knock.....not that common but getting more so as everyone is changing bushes apparently.
    Can fault Midland VW top top garage, will defo be using them in the future.
    Be careful with those bolts boys.
  12. Westy
    17,442
    1,100
    The audi technician I know actually advised me to use brand new bolts too. I haven't though.
  13. fossie
    fossie Member
    207
    Cheers for the links - just ordered mine
  14. steviet
    steviet Member
    439
    Hmm aint sure if its the mount as it sounds like a clanging noise,something loose!..perhaps i should get some new bolts then i can cross that off if its that or not...maybe the coils hitting each other?..it is very low!
    One other thing,any other good mounts worth replacing/uprating?.
  15. audi-tk
    audi-tk Member
    441
    how much are the bolts?
  16. Westy
    17,442
    1,100
    Not too sure. Probably a good £3 each as they're quite hefty.
  17. audi-tk
    audi-tk Member
    441
    oh thats ok-ish. you think its worth buying them. dont think my dog mount has ever been changed tbh
  18. R1KVX
    R1KVX Member
    108
    have fiited mine yet, glad i ordered the bolts as well though!
  19. Westy
    17,442
    1,100
    To be honest. Audi technicians will advise you to change most bolts when changing parts.
  20. finesse
    finesse Active Member
    2,805
  21. steviet
    steviet Member
    439
    Dont surpose anyone has the part numbers for the bolts please?
  22. Sam_
    Sam_ Down under
    3,035
    480
    Including the wheels? ;)
  23. audi-tk
    audi-tk Member
    441
    Yeh part numbers would be good
  24. Agric04
    Agric04 Member VCDS Map User
    288
    Can also vouch for this being a good mod for the money.
    Awesome gti fitted mine on Friday and wow it makes a very noticeable difference. Would never have considered it had I not seen this thread so thanks guys.
  25. SiGainey
    SiGainey Member
    505
    9
    Can I get a thanks for everyone that found this useful then please :) haha
    S3Lol likes this.
  26. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
  27. Westy
    17,442
    1,100
    Stop posting pics and get under your car! ;)
  28. voorhees
    16,126
    1,968
  29. Westy
    17,442
    1,100
    Nice answer smart arse ;)
  30. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    ive give you a thanks seen as you havent got many......lol
  31. voorhees
    16,126
    1,968
    :shutup2:
  32. wayne1.8t
    wayne1.8t Member
    150
    Bit of help if poss please just doing mine now undone all the bolts but one of the heads on the 13mm bolts decided to snap off, how can I get the mount of now? Is there threads on the mount hole which the bolt goes through what will stop it sliding off or can I just try pulling it off over the thread what's left??????
  33. wayne1.8t
    wayne1.8t Member
    150
    Pleeeeeeeese!
  34. [Dave B]
    [Dave B] Daddy
    2,027
    145
    There's no threads in the mount that comes off, there's only threads in the subframe. This happened on mine, I eventually managed to pull the mount off through the repeated use of heat/plusgas/hammer and screwdriver! I think lots of heat was the key though....
  35. wayne1.8t
    wayne1.8t Member
    150
    Thanks mate 20min job turned into alldayer.
  36. S3Lol
    S3Lol Member
    422
    has anyone bought that small round bush for the other end of the dog bone mount? is it worth getting?
  37. mrj0ey
    mrj0ey Member
    105
    Very hard to press out.....stiffens it up a lot though. You can get void fill bushes, just fill the void in original bush...easy to do , stiffens it up by 17-20% for about £15....superpro void fill bush.....good comments about that on the interweb.
  38. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Agreed. The problem is that there is a happy medium between too stiff and too soft.
    Too stiff will give you a LOT of vibration in the cabin which is very annoying and uncomfortable. Too soft allows excess engine movement.
    I'd say that just doing the main bush is sufficient.
  39. audi-tk
    audi-tk Member
    441
    got mine done. cars shakes n vibrated from dashboard but not that bad! feels so much better! out my foot down n response is instant gears feel a bit better going in too :) defo worth doing.
  40. vanilla_ice
    vanilla_ice Member
    693
    22
    Does anyone know what torque the bolt that clamps the bushes together should be? i.e. not the 2 x 13mm bolts and neither of the "long" or "short" 16mm bolts.
    Hope that makes sense.
    EDIT: Torque the compression nut to 20 Nm (15ft-lbs) + 1/4 turn
