How can you tell if you have a DPF fitted?
ecnirp98 Feb 12, 2013
  1. ecnirp98
    ecnirp98 New Member
    25
    Hi
    I have a May 2008 A3 2.0 TDI 140 Diesel, losing power at around 3000RPM and won't go higher in high gear 4-6, its ok in low gears 1-3, so wondering if it could be DPF? I cannot see any DPF light on the dash when i turn the ignition.
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    From memory I do not think the 140 has a DPF.
    Take the car for a scan
  3. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    I think some of the newer 140s have it though but not sure when it was introduced.
  4. southylad
    southylad Active Member
    544
    I think 58 onwards from what ive been told
  5. ecnirp98
    ecnirp98 New Member
    25
    Mines an 08, I have the Audi Service Schedule book with the Vehicle Identification Data sticker in it, can you tell from those codes?
  6. southylad
    544
    I am not sure mate sorry
  7. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
    Could be a blocked up EGR valve......Audis are prone to it.
  8. robbiedondo
    robbiedondo New Member VCDS Map User
    22
    Mines a 58, 170. Service book sticker in the middle DPFM6S = DPF,manual 6 speed.
    Hope that helps
  9. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    8P2 140pd models= no dpf
    8P3 140cr models = dpf. :-(
    Hope that helps mate.
  10. ecnirp98
    ecnirp98 New Member
    25
    Cheers, my sticker middle is:
    103 KW M6S 04/08
    BKD
    no mention of DPF, so I'm guessing its not a DPF.
    Just trying to rule things out for the power drop out.
  11. ecnirp98
    ecnirp98 New Member
    25
    Where did you get the code from? on my sticker it is :
    8PA CLC
  12. ecnirp98
    ecnirp98 New Member
    25
    I'd heard that, but I was told there would be allot of smoke from the exhaust which I'm not seeing.
    The Halfords repair centre gave me code P0234 when they connected to Diagnostics, they said thats booster overload, they said it was turbo related, but were not sure what would cause it without stripping out the turbo, which I wasn't happy about doing there, the car is still drivable and its just top end speed/acceleration that is hit in high gear, I didn't want to end up with a turbo in bits and never working again.
    Could the top end speed drop off be 'limp mode' triggering? it never triggers in low gear/high RPM.
  13. AndyA3170
    AndyA3170 Guest
    Can you tell if you've got one cause your in and out of the Audi dealership constantly lol
  14. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Look for option code 7GN - if this is shown then NO DPF is fitted.
  15. Dannykn9
    1,123
    56
    8P1= split grille model
    8P2= Single Big grille model
    8P3= last face lift model 58 plate onwards.
  16. Dannykn9
    1,123
    56
    You have a BKD engine, so am guessing an 08 plate. You have an 8p2 model 140pd, so no DPF.
  17. ecnirp98
    ecnirp98 New Member
    25
    Yep, it's an 08 plate, registered May 08, so its 8P2 model, so no DPF, that's something I can rule out then.
    Thanks.
  18. ecnirp98
    ecnirp98 New Member
    25
    Mine is 8P2 as it was registered May 2008, 08 Plate, 8P3 started June 2008, its the big grille, but I cannot tell difference in pics between 8P2 and 8P3 facelift model !!!!
    Thamks
  19. A3Kent
    1,570
    249
    I have seen one 8p3 on an 08 plate btw. Get a photo of your car up so we can confirm
  20. NHN
    29,417
    1,740
    BKD is 03-08 & isnt dpf & not facelift either.
  21. icekay
    icekay Member
    79
    I have a 58 plate 2.0Tdi 140 and i have DPF
  22. A3Kent
    1,570
    249
  23. Dannykn9
    1,123
    56
    you have a 140CR engine 8P3 facelift which has a DPF. The 140PD engine 8P2 model pre- facelift does NOT have a DPF.
  24. Dannykn9
    1,123
    56
    Good find! I forgot about that thread.
