helpppp!!!!! Jetex filters or Bmc cone, bmc induction
valyboi Dec 5, 2012
  1. valyboi
    valyboi Member
    120
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Buy the cheapest, none of them will make any difference.
    They'll probably make the car slower in fact.
  3. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I would set Jetex and make sure it gets as much cold air as possible or stick with a standard airbox filter.
  4. Mr Footlong
    Mr Footlong Stalking Kate Beckinsale
    52
    I have a BMC CDA kit that I bought for a laugh for my old XJR but realised as soon as I fit it (did less than 5 miles on it) that I wouldn't be able to feed in as much cold air as I wanted to it due to the engine bay being full of engine.... It should have 90% or so of the parts that you will need and I don't want much for it, was going to sell it for £100 + delivery.
  5. valyboi
    valyboi Member
    120
    I'm new too audis tbh so what iv heared if I get some sort of cone filter I need a cold air feed too or Il loose power by sounds on it, also is it true if I get a panel filter upgrade will it mess the MAF up
  6. 16Klappe
    5,795
    1,186
    In the nicest possible way mate...
    It's a 1.6, don't bother.
  7. valyboi
    valyboi Member
    120
    I appreciate what you mean but reallry I just want the noise & not too loose power
  8. Vex182
    1,035
    79
    Make sure it gets cold air and then you should get the noise your after and still avoid to much heat soak.
  9. valyboi
    valyboi Member
    120
    Thank you very much if I would get some sort silicon pipe to fit to my MAF then cone at the end this should help as it be closer to the wing and fit nice 3" pipe cold feed from the grill or fog should this be ok close to the original feed
  10. 16Klappe
    5,795
    1,186
    You can route a cold air feed between the battery box and the wing, personally I would try to buy one of the CAI's for a 1.8t and try and butcher it to fit.
    The MAF is in the same place so it should be easy to modify.
    Popping out a fog light for a cold air feed is the most disgusting thing imaginable. Please don't do it.
  11. valyboi
    valyboi Member
    120
    Thank you very much for the info and that looks a clean engine bay there 16klappe so basically if I find a cone I like all I got to do is use some sort of cia for a 1.8t any chance you any links for these
  12. 16Klappe
    5,795
    1,186
    That isn't my engine bay.
    Ebay, they are £30.
  13. valyboi
    valyboi Member
    120
    YeH Il route it behind the bottom grill I think, I can't seam to find one on eBay
  14. valyboi
    valyboi Member
    120
    its okay iv found one now, but I don't understand how I'd put the filter and wear or do you me do it same as the pic just put filter half way cut the pipe where it normaly goes
  15. 16Klappe
    5,795
    1,186
    The filter goes on the end of the pipe, down in the front bumper.
    valyboi likes this.
  16. valyboi
    valyboi Member
    120
    I suppose it will look netters under the hood, but the filter will get stinking all the time
  17. 16Klappe
    5,795
    1,186
    I'm not sure what that means.
  18. valyboi
    valyboi Member
    120
    If the filter will be by the bumper wouldnt it get a lot dirty than normal, I can't seam to find that cold air intake like that at that all ones I find are all one peace
  19. 16Klappe
    5,795
    1,186
    Correct, it would get dirty.
    And yes, they are all one piece that I have seen. That is the first one I have seen with a split in it.
  20. valyboi
    valyboi Member
    120
    I will have to look for close up pics of this to see where the filter goes exact, I think look of this on a 1.6 would make you look twice atleast, have to clean it every week lol, I do like the look whos car is this do you know
  21. 16Klappe
    5,795
    1,186
    Not a clue. That engine bay looks pants to me, it's just a standard car with a £30 CAI.
    I can tell you exactly where the filter goes, down behind the front bumper between the wheel arch trim and the bumper. It sits behind the horns. I should know I ran one for years.
    It will be exactly the same behind your bumper as any other A3.
    The pipe for the kit looks like this -
    And the tabs mount on the original airbox mounts, the tabs are the same between a 1.6 and an A3 so I'm sure all you will need to do it make correct adapters for the MAF sensor.
    valyboi likes this.
  22. valyboi
    valyboi Member
    120
    Thank you very much I deffo have to do this now, just find the correct pipe ect, did you find it was better than using Normal filter with cold feed pipe
  23. 16Klappe
    5,795
    1,186
    A normal filter with no cold air feed is the setup I have, and it is much better than one of these CAI kits in terms of longevity and filtration purposes.
    No need for a cold air intake on my car, it's a 240bhp 1.8t and the IAT's are 24* peak and 9* minimum due to the intercooler.
  24. valyboi
    valyboi Member
    120
    okay thank you for that thats much more help so would i do the cai option or just get a nice cone with the cold air feed on my 1.6 i am liking the cai thing tho its diffrent for a 1,6
  25. firestorm
    firestorm Member
    371
    OT -Jardo, where did you get the info display from?
    cheers
  26. 16Klappe
    5,795
    1,186
    It is an app called Torque, only available for Android.
    It allows you to take readings from all of the vehicles sensors in the same way VAGCOM does, you can display them in a dashboard like this and it will do logs, clear fault codes, record videos with the information overlayed and all sorts of things.
    The boost seems innacurate but that is due to my own setup, however the other values are pulled straight from the ECU.
  27. firestorm
    firestorm Member
    371
    Thanks Jardo- I presume it'll need a cable or a wireless obd2 widget?
    Like a liquid gauge?
  28. 16Klappe
    5,795
    1,186
    Pretty much liquid for your phone yeah.
    It only works on facelift/ME7 cars though.
  29. firestorm
    firestorm Member
    371
    Great, should work with my bam engine then
  30. valyboi
    valyboi Member
    120
    Finaly got my self a jetex filter all need now is filter adaptor
