Help replacing headlights
slizza786 Aug 13, 2013
  1. slizza786
    slizza786 Active Member VCDS Map User
    394
    25
    Hi
    I have an Audi A3 (04 plate) 2.0 TDi with fog lights and want to change the halogen lights to some super white halogen ones. Iv found a full kit which includes the main beams, side lights, dipped beams and fogs. The problem im having is fitting them onto the car because i wont be spending £7.99 on each bulb at halfords to fit them on. If someone who knows how to change them wouldn't mind sharing some knowledge i would really appreciate it.
  2. hades-
    9,481
    646
    really ?
    you take the back cover off remove old bulbs
    refit new bulbs and place cover back on
    if you cant do this then take it to a garage and pay to have them fitted
  3. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    It isn't difficult, just very fiddly to get your hands in. My word of advice would be to find someone with small hands and if you can't, get some long nose pliers, it'll make the job a lot easier.
  4. slizza786
    394
    25
    Thanks for the response guys. Iv attached some photos here hopefully to show where im getting the trouble from.
    for this part i dont know what is keeping the bulb in place i cant seem to find the correct hook to release, has it got something to do with that metal ring?
    As for the main beam I didnt want to risk moving it around until I know which part to undo. Where do I start off?
    Finally for the fog lights is there a specific part when I have to pull to release it off the bumper?
  5. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    With the main and dipped beam you just pull the socket with the bulb out.
    Fog lights - if I remember correctly you can pull out the grilles to have easier access to the rear or could also unscrew them after removing grilles.
  6. slizza786
    394
    25
    thanks guys im going to try this out and see how it goes
  7. slizza786
    394
    25
    With the high beams I was able to pull it out of the socket and take the bulb out. However I'm still finding it hard to come in contact with the main beams because if the black box blocking it
  8. slizza786
    394
    25
    ignore that last post just found the clip to release the cover if this box
  9. hades-
    9,481
    646
    good find your big red arrow is pointing to it :jester:
