Help needed please.... B5 AVANT SLIGHTLY MODDED
Steve B5 Biker May 11, 2012
  1. Steve B5 Biker
    Steve B5 Biker Member
    137
    14
    Hi all Audi fans, i need advice and any pointers as to costs/remedies/causes of the following problem ,
    My 2000 x reg A4 2.5 tdi avant, has developed a serious issue best described as clutch judder,shaking the car /engine quite violently,this only seems to happen when moving off from a standing start , it happens only once i have done several miles of normal driving conditions, then after getting into heavy traffic and or lots of clutch work/ parking and slow manouvering it suddenly appears,.
    I have read posts on here, re moisture on clutch plates a possible cause ? any other advice- experiences of same or simular problems would be most welcome ...
    Cheers in advance for any replys
    Steve:unsure::scared2:
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    sounds like clutch/ dual mass flywheel. how many miles has it done?
  3. Steve B5 Biker
    137
    14
    Hi Heinz,the car has 153k but dont know if its original clutch or not !!!!
    No history as such with car.
    Thanks for reply
  4. Bradderz_1988
    3,958
    240
    Id go with dual mass flywheel but give the mounts a once over i had a similar problem on my old 1.8 ADR and found the alloy part off the o/s mount snapped in half.
  5. murran
    murran Well-Known Member
    1,545
    39
    sounds like a clutch issue to me, once the friction plate gets warm. might be part contaminated with oil? section of the plate material breaking down?
    think the car would have to had very good careful drivers to get it to 153k on one clutch.
  6. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,734
    165
    I concur, the clutch is the likely culprit as mentioned above. Same thing happened on a Saab 9-5 3.0 Tid I had. Luckily, I noticed it during a test drive and was replaced before I actually purchased the car. That too was dual mass and cost the bloke nearly half the asking price of the car! :)
