heated miirrors
bearder2006 Nov 15, 2010
  1. bearder2006
    bearder2006 Member
    205
    how hard is it to put them in as my cab dont have them and what would i need ?:readit:
  2. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    I'm not totaly sure myself, sorry, but my I ask, and going of topic! What wheels do you have on your convertible and what size are they? They look good.
  3. CHRIS555
    1,970
    10
  4. unikarl
    unikarl Member
    367
    I read somewhere its just a case of buying the glass with a heating element and pluiging in the existing wires.
  5. Wrath
    Wrath Well-Known Member
    1,196
    41
    Are you sure you don't already have them?
  6. CHRIS555
    1,970
    10
  7. mitch2575
    mitch2575 Member
    107
    i have on my cab but only the drivers side is heated?? it only works when i put on my rear dimister!! is that correct??
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,203
    2,690
    What does your User Manual say on the subject?
  9. CHRIS555
    1,970
    10
    I don't even know if mine are or not - i think so - i'm going to check my manual now!
  10. Wrath
    1,196
    41
    Yep, they should only work when the rear heated screen is switched on. Whether it also checks the outside temperature as well, I'm not sure.
  11. bearder2006
    bearder2006 Member
    205
    hi when i took the mirror cases off there was no wires on the mirror but there was some wires in there so the idea with the rear heated screen dont work on mine .
    as for my wheels they are 19" s5 alloys
  12. Masterm8fo
    Masterm8fo Warmonger
    342
    i dont have these either - seems crazy to not add such things as standard on such a prestige car.
    My neighbour has a W reg Chrysler Neon and he has them ! cheers Audi...
  13. jsh
    jsh Member
    112
    I did my B7 Cab this year (S-Line) It was just a case of buying heated glasses. The wiring was there and plugged into a dummy terminal on the existing mirror glass. Operates with the HRW when the temp is below 4 degrees and the mirror control button is in the centre position. To be honest, I don't know why Audi don't fit them as standard. The existing mirror glasses are easy to break when you remove them so be prepared
  14. bearder2006
    bearder2006 Member
    205
    thats it im getting some
  15. bearder2006
    bearder2006 Member
    205
    any body got the pair just want the glass ?
  16. Johnytuono
    Johnytuono Member
    131
    ...my drivers side works but not the passengers. Is this a fault? (B7 S Line Cab.)
    Ta
    JohnyT
  17. Masterm8fo
    342
    how much are these and anyone know part no's ?
    they are a must with the coming weather...
  18. old-man
    old-man Member
    39
    Someone posted 8E08575735D and 8E0857536E when I asked the question last year, but dont know if they are correct or not. I believe I paid about £60 for both.
  19. bearder2006
    bearder2006 Member
    205
    there was a set on ebay went for 20 dam missed them
