Heated Front Windscreen
Freddie2112 Mar 22, 2013
  1. Freddie2112
    Freddie2112 New Member
    22
    Hi,
    Is it possible to have a heated windscreen? (New screen required I know)
    I had one in my Mondeo ST TDCI and it was really handy but on the other hand if its awkward to do or expensive then scrapper and Di icer it will be ha!
    I have an B8 Audi A4 avant 3.0 TDI (240BHP) by the way just in case this matters.
  2. mike60eley
    mike60eley Active Member
    616
    195
    43
    I believe Ford own the "rights" to the technology so they patented the idea so it costs money for other companies to use that idea, not 100% sure thou.
  3. NHN
    29,351
    1,720
    I see no option on a B8 for heated screen.
  4. CHEZ
    CHEZ moderately amusing Supporter
    4,172
    840
    this is correct
  5. Freddie2112
    22
    Well that has answered that then! Thanks guys :)
  6. @ndr3w
    @ndr3w Member
    60
    Agree, I miss the heated screen that was on my Mondeo. Would have thought the Germans found a way of developing another heated screen which does not infringe Ford's rights..?
  7. rosscotdi
    rosscotdi Member
    118
    I would love this and would pay good money! On a similar topic has anyone noticed there appears to be some sort of heating on the windscreen were the wipers park that must be electrical cause it works pretty quickly when scrapping the windscreen
  8. @ndr3w
    @ndr3w Member
    60
    Have not checked my A4. I once had a Lexus IS200 which had a heating element built into the front screen where the wipers sit. This was to stop them sticking in cold weather.
  9. 5102 IA
    5102 IA Member
    66
    9
    The Ford patent doesn't appear to be such an issue in the aftermarket. Heated screens are available for most rally cars - I've a heated screen in my Opel Manta track car from these guys:
    UroGlas - Heated Glazings
    (sure others are available too)
    We had a group buy and they came in at £110 each with a minimum run of ten if I remember, but that was getting on for 10 years ago now and they dont come much simpler than Manta screens. I suspect with option on the B8 such as auto lights, wipers, acoustic glass etc thing could be considerable more expensive!
    The B8's an unlikely rally car so I doubt they've any off the shelf, but they may be interested if enough people are interested and you dont mind the aftermarket aspect.
    The heating elelment is separate on the Left and Right sides requiring a 30 Amp relay for each side - simple enough, old fashioned wiring.
    Ian
  10. A3BE
    A3BE Member
    69
    Both Land Rover and Mini use heated front screens too, so I am not entirely convinced Ford own the patents outright on this basis.
  11. rosscotdi
    rosscotdi Member
    118
    Hmm land rover are owned by ford, mini on the other hand being owned by BMW not sure about that one
  12. mike60eley
    616
    195
    43
    Google seems to say that the wire-embedded-in-the-screen technology was owned by Ford, they did grant limited licences to select competitors such as for use on the BMW etc.. but it looks like they have lost the patent or it expired?
  13. A3BE
    A3BE Member
    69
    Land Rover are no longer owned by "Fraud". Indian steel tycoon Ratan Tata purchased Land Rover in 2008. Land Rover come under the umbrella of Tata Motors Group.
  14. shariain
    shariain Well-Known Member
    1,182
    190
    I have a heated screen in my Vw sharan 05plate. It's the one with the wires embedded through the screen.
  15. @ndr3w
    @ndr3w Member
    60
    So if VAG have done it once! :) To be honest, my butler pre-warms and defrosts my car!
    CHEZ likes this.
  16. PMWolf
    PMWolf New Member
    The VW Sharan and Ford Galaxy was the same car and was a joint venture between Ford and VW, hence why it has the heated windscreen..
  17. a4sline
    a4sline Member
    185
    The heated front screen is a factory order option on the Skoda Superb and is identical to the Ford set up.
    If Skoda use it, why not Audi...... brilliant idea, must be down to politics I guess.
  18. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    Recall seeing that the VW Passat had a "wired" heated front screen option 3-4 years ago when I had a brochure.
  19. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    fit an aux heater instead ;)
  20. @ndr3w
    @ndr3w Member
    60
    What about running an extension lead from your house and wrapping your screen with a heated bed blanket? May be difficult when not at home. I would suggest a generator for this.
    Dragons Den - Here I come!
  21. Glassman
    Glassman Seasoned Noob
    89
    41
    Link?
  22. NotNormal
    NotNormal Active Member Team Nano Grey VCDS Map User Audi S3 quattro s tronic
    319
    59
    The VW Passat 2007 shape has the option to have a heated front screen. Never seen one until my friend turned up with it, now I've seen about 5 of the bloody things (with work)
    The VAG group do offer them for some vehicles....
  23. Spotted
    Spotted New Member
    Hello,
    has somebody asked from these guys about B8 windscreen?
  24. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,232
    171
    Check what the sweeds have on their options list.
    Volvos and the like up there can get heated screens and I'm 98% sure the sweed and danes can have heated screen options in their cars. But most of them have aux heaters plugged into the garage anyway.
  25. Spotted
    Spotted New Member
    Thanks, will check. I have aux heater aswell. This helps a lot when starting to drive. But in certain conditions trobles start during the drive. Like -10C° or colder and constantly snowing. Other option is to blow too hot air too much but this can get annoying.
  26. AudiLeon
    2,232
    171
    http://www.audi.se/content/dam/ngw/se/2015/pdf-modellbroschyr/A4_533.1153.40.37.pdf
    The above link is to Swedens brochure for the latest A4.
    Page 74 - Vindruta, eluppvärmd (Windscreen, heated)
    The section is Glasytor (glass surfaces)
    I could be talking poop, but if they have it for the latest model in Sweden. They might for the B8 / B8.5.
    Scrap all that, It's available on the B9 in the UK too. But I wrote too much just to delete it lol
  27. Spotted
    Spotted New Member
    Yes, 2016 model has it in every region. I guess. Looks like glass with the same parameters as the whole body looks basically the same. But unfortunately you can be sure when you compare them side by side.
