Forge Breather Hoses - apparently they won't fit an AMK S3?
DJ_Troopa Jul 27, 2010
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Afternoon!
    I'm looking at buying the Forge breather hoses for my car as i have a split in 1 of them under my inlet mani. I looked on the Forge site and they only have it listed under the MK1 TT range but not for the S3? I spoke with Forge tech team on the phone and they said on ETKA the pictures for that part of the engine bay are the same for S3 & TT but the part numbers are different. Then they said they have only tested the hoses on the BAM engine and so they're not sure about my AMK. I thought the engines were the same when it comes to things like this?
    I have spoken to DPM as he sells them aswell and i told him what happened but he cannot confirm either if it will fit the AMK engine.
    This is what i'm after (below), can somebody please confirm if it will fit my engine? Looks like the same stuff to me!
    http://www.dpmperformance.co.uk/for...er-hosesbr-s3-8l-18t-quattro-0199-p-5703.html
    Thanks!
  2. Sandip
    2,449
    91
    I put them on this afternoon Troopa, fit no problem:)
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Perfect! Cheers dude! You get them from DPM?
  4. Sandip
    2,449
    91
    No, got mine from Awesome Gti bud, are you changing any other bits or just these hoses?
  5. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Just these hoses dude as i got a leak in 1 of them. Don't think i need anything else. How much did you get them for delivered?
  6. Sandip
    2,449
    91
    I got them from Awesome direct bud, you could do with changing the whole lot, i know it's expensive but the amount of sludge in the breather pipes is shocking. Do it once then you'll never have to touch that part again:)
  7. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    When you say changing the whole lot, what other hoses are there? The kit i'm looking at has 3 hoses.
  8. Sandip
    2,449
    91
    I changed all the ones with the red dot next to the part numbers. The amount of sludge in the pipes was pretty bad Troopa. If you haven't changed the E shaped hose i've marked with an arrow already i'd do that too, they split from the inside.
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    This is what i'm looking at, which ones are they in that picture?
    Where did you get the other hoses from you replaced?
  10. Sandip
    2,449
    91
    These are the Forge replacement bud
    06A 133 783 AS
    06A 133 783 BA
    06A 133 783 AT
    Got the other ones from Audi:)
  11. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    What's the E shaped hose called? Do Forge do silicone for that one?
  12. Sandip
    2,449
    91
    I bought the whole thing (06A 133 789), don't think Forge make this hose for the BAM and AMK engines. You could remove it and have a quick look to see if it is split, mine had a mist of oil misting on the side of the intake mani so that gave it away for me lol
  13. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Thanks Sandip. I've ordered the Forge breather hose kit and brake vacuum hose all from Forge. Got so much to get fitted now, i've actually got a list!
  14. Sandip
    2,449
    91
    Good stuff, i give mine a good jet wash whilst everything was off, nice n clean now:)
  15. finesse
    finesse Active Member
    2,805
    is there no alternative to forge?
    sanip, who is chipwizard?
  16. Matt82
    Matt82 Active Member
    2,365
    worst case, custom make it
  17. finesse
    2,805
    forge...........
  18. Matt82
    2,365
    is that to say the difference between organic rubber and synthetic silicon?
  19. Sandip
    2,449
    91
    He's a mapper i've known for years, Wayne Schofield (chipwizard based in Rochdale)
  20. finesse
    2,805
    excuse my fanboy attitude, but
  21. Sandip
    2,449
    91
    I know John, i just want custom map to suit my car, if i was to choose any plug and play i think it would be CC Phase2 or their new CC VVT Attack thing:)
  22. vanilla_ice
    vanilla_ice Active Member
    704
    26
    Hi Sandip,
    Are all of the part numbers in the picture correct for AMK's? Thinking of replacing the lot with OEM parts. Any idea on cost?
    Cheers,
    ICE
  23. Tony gold
    Tony gold Member
    205
    So will these fit an 199 s3?
  24. Sandip
    2,449
    91
    All the part numbers are good for the AMK/BAM engines, i replaced parts 783-AS, 783-BA and 783-AT with the Forge alternatives > Awesome - Forge Silicone Breather Hoses for the 225hp 1.8T.
    These are the main ones i think you should change first as these are the ones that split with age which = boost leaks
    I also changed 213-F, 247 and 245-A.
    And i also changed the crankcase breather hose to this recently > Awesome - Forge Silicone Cam Cover Breather Hose VAG 1.8T 225
    Prices (July)
    06A-103-247 - £3.04
    06A-103-213F - £19.93
    904-673-01 - £3.21 (o ring for 213F)
    035-103-245A - £6.12
    06A-103-213AK - £32.00 (this is the tube what goes on the other end of 06A-103-247,it'll be brittle)
    Forge breather hoses (3) - £27.97
    Total - £92.27
  25. vanilla_ice
    704
    26
    Thanks Sandip. I think I have got all the correct part numbers. I am replacing all pipes with OEM and also replacing the suction pump (058-133-753-D - £18.71+VAT) and 06A-133-789 (£49.97+VAT).
    Just wondered about:
    Mine looks OK at a glance. Can that pipe be easily replaced on it's own, or would I be better to do the whole lot at once?
    Thanks again.
  26. Sandip
    2,449
    91
    No it can be done after if you wanted, i just thought i'd mention it because it's a dealers only part and it'll take a day or to get lol
  27. vanilla_ice
    704
    26
    Thanks for the heads up. Maybe I'll take a closer look before I get stuck in.
  28. Nilz
    11,331
    881
    Hey Sandip, quick question, you know the E shaped hose, have you got the part number for it, as when looking on the system, they are only showing a U shaped one, has it been upgraded??
  29. Sandip
    2,449
    91
    Unfortunately the E shaped hose comes with 06A-133-789, the U shaped one is for the APY engines
  30. Chlippo
    Chlippo Member
    679
    15
    out of nowhere but in hoses and silicones...
    i bought an autobahn88 tip for my AMK, didnt fit it yet, but at first look it doesnt seem to fit, the oem part is kind of bigger and longer....
    didnt try yet.
    thoughts?
  31. Tony gold
    Tony gold Member
    205
    Any thoughts anyone if this kit would fit a 1999 s3 210 bhp? Cheers
  32. Sandip
    2,449
    91
    Slightly different on the 1999 as it's APY, got a secondary air pump thing, i know for sure the APY's don't have an E shaped hose though, have you got split hoses Tony?
  33. Sandip
    2,449
    91
    Get some pics up, if it's the right tip it should fit lol
  34. vanilla_ice
    704
    26
    As I'm planning on replacing the pipes myself, using the following guide: PCV valve and hose replacement for AMU engine (BWW and long) - AudiWorld Forums
    What tools do I require? 10mm socket, 6mm allen key, 5mm allen key, then snips to cut original clips and screw driver for "c" clip and new new jubilee clips?
    The guide makes it look quite straight forward to me, but scares me if the inlet manifold has to be removed. The guide suggests that having OEM small vacuum hoses might mean the inlet manifold will need to come off.
    Has anyone found this to be the case?
  35. Tony gold
    Tony gold Member
    205
    Hi Sandip, no i haven't got any hoses split,just thought i'd change them anyway as slowly replacing a lot of things on the motor
  36. Sandip
    2,449
    91
    I see, take the part numbers above to Audi and see if they are ok for yours (APY), the 3 Forge hoses could be the same, not sure though
  37. Tony gold
    Tony gold Member
    205
    Nice one cheers Sandip,going to put up a load of pics of my car soon as just spent over well over 3K on mods and a full respray
  38. Nilz
    11,331
    881
    Ordered 06A 133 789 today, should have it tomorrow and will fit over the weekend and then see how I get on, if I need to get the rest of the pipes I will do accordingly and see what comes of it.
  39. Sean_S3
    Sean_S3 Member
    323
    17
    Thanks Sandip for posting this. I've just had my car serviced and i got an advisory for oil mist under the inlet manifold which they put down to split breather hoses.This will come in handy when i come to change them.
    Cheers.
  40. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,543
    1,459
