Fast ticking/metalic ratchet sounding noise when wheel spinning in snow
Benjiman46 Feb 7, 2012
  1. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Hi all, I am a bit worried about a noise my 2000 S3 Quattro 8L is making when it wheel spins in snow.
    The sound comes from the drivers side at the front, and kind of sounds like ABS, except its when the car wheel spins in snow without pressing the brake.
    I was just wondering if anyone else has this same noise? I'm hoping its not the gearbox or haldex or some other expensive **** lol
    I have only noticed this in the snow as it's very hard to wheel spin otherwise.
    Any ideas will help
    Ben
  2. Alais DJA
    Alais DJA Member
    559
    50
    Bearings
  3. CHEZ
    CHEZ moderately amusing Supporter
    4,189
    867
    DMF!
    sorry!
  4. Keiran
    Keiran Member
    89
    Hi mate, I have an a3 1.8t Quattro an have been getting the same problem when having a bit of fun in the snow. Doubt it's bearings mate ud hear it while driving normally aswell. I seem to think it maybe the engine mounts in specific the rear one gonna have a look at it at the weekend. Do u get the same noise when you bring the clutch back up after changing gear as I do. Let me know if you find any more info out,
    Cheers.
  5. Benjiman46
    551
    24
    Ok... DMF? lol
  6. CHEZ
    4,189
    867
    dual mass flywheel!
    problamatic area that creates all sorts of issues!
    this includes a clutch also to fix if indeed it is causing the noise issue!
  7. Benjiman46
    551
    24
    Hmmm I dont think it's engine mounts... I cant hear it at any other time other than when it spins up in the snow. Any gear, any revs, it's more or less the exact same noise you get when the ABS cuts in, similar vibration too. I will let you know mate ;)
  8. Benjiman46
    551
    24
    Ohhhh no it's definitely not that. Wrong side of the car for a start lol
  9. Benjiman46
    551
    24
    What bearings do you mean? Wheel bearings? Like Keiran said, I would be able to hear it all the time when driving. Under normal conditions, I cant hear anything. It is only the "ABS-like" sound when wheel spinning on snow.
  10. george_seamons
    george_seamons Active Member
    323
    86
    Its neither of the above. Its perfectly normal.
  11. Benjiman46
    551
    24
    Oh ok, What causes it?
  12. george_seamons
    323
    86
    ABS/TC...basically its the safety "brain" going nuts because it doesn't know what is going on
  13. Benjiman46
    551
    24
    Oh cool :) fair enough :) Do you work for Audi or something? lol Thanks for your advice mate :)
  14. george_seamons
    323
    86
    Nah, just I've had the very same, and wondered the same thing! Always nice to know there's nothing to worry about :)
  15. IrishDave
    IrishDave Active Member
    682
    45
    Sounds like a c.v joint to me.
  16. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Its the traction control trying to cut power to the spinning wheel...:)
    If the traction was off i would go for a noisy CV joint that is not under load...
  17. smokiedee
    smokiedee Member
    118
    nothing to worry about my focus i had before used to do it, it's part of the abs system
