FAO People with dodgy Central Locking - Boot release
cjp2k Apr 3, 2008
  1. cjp2k
    cjp2k Active Member Team Tango Audi A4 S-line owners group saloon
    260
    25
    Hi guys, some of you are suffering from the boot not opening with the rest of the car.
    My car is in Audi today and they have found a fault. It needs a new central locking control unit,
    My car is stripped down atm at they are waiting on parts. So got a 2.0T as a loan car:rock:
    Does anyone know where the central locking control unit is located in the car?? As I will check for rattles when its back!!
    Will keep you updated guys!
    Chris
  2. h5djr
    9,423
    1,747
    As far as I can ascertain from my information the central locking is controlled by the central control unit for convince system. This control unit is located behind the trim panel on the right-hand side of the luggage area.
    Hopefully it shouldn't cause too many problems.
  3. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    Ah ha so its not only me who has this problem!!!!!!!!!!!!!!!!!
    I have got it where if i press the button twice sometimes the boot doesn't open!
    So what i have done is turned on the setting where one press unopens all the doors and lock using vagcom!
    i'll take the car to Audi.
  4. redbutcher
    redbutcher Member
    649
    Great - thanks for the update - have sent you a PM cjp2k, but this answers it. Looks like I might need the same on mine then - will get it booked in as soon as.
  5. L60N
    L60N Guest
    I only open the boot by holding down the button for a couple of secs, then it pops open.
  6. redbutcher
    redbutcher Member
    649
    L60N - the boot should unlock (not open though) when the car is unlocked - either 1 or 2 presses on the unlock button on the remote depending on how your car is set up.
    My boot isn't unlocking at all when the car is unlocked, so I'm having to use the middle button on the remote all the time just to get in the boot - it's really annoying!
  7. L60N
    L60N Guest
    OIC. hmm, better check mine then! i know this much, its usually locked so have to hold the button down to pop it :unsure:
  8. bacardi
    bacardi Active Member
    1,139
    you may need to get the timing right between the button presses as mine is very sensitive
    Basically, when you manage to get it to open all 4 doors, the boot too is unlocked
  9. biryets
    biryets New Member
    12
    I used to think that mine was faulty till I discovered how to do it.
    Its all in the timing.
    1. The first press of the unlock button unloks only the driver's door.
    2. If you press the unlock button again in less than one second, the rest of the doors will unlock but the boot will remain locked.
    3. if you press the unlock button for the second time 2-5 seconds after the first press, all doors and the boot unlock.
    I this is not documented anywhere else but you should try it. It works for me all the time.
  10. cjp2k
    260
    25
    Yeah just seen that mate, was going to point you to this thread!
    Hopefully will get the car back for the weekend, but I am not hopefull!
    The 2.0T is great fun, but its got a drink problem compared with the TDI!!
    Apparently the Central locking unit kicked up a error code on the dealers computer. But not sure why this wasnt picked up last time the car was on their diag systems!
    Just out of interest how old is everyones car who has this problem??
    Mine is a March 07
    Chris
  11. redbutcher
    redbutcher Member
    649
    Mine has never worked like that - first press, drivers door only, second press all other doors and boot.
    Now I have removed selective unlocking, so one press should unlock all doors and the boot and it doesn't (and yes I have tried pressing again just in case).
    Chris - thanks for that - might have to wait a bit to get my car in as I'll need a car and they are normally booked up at least a week in advance.
    Oh well, I don't mind waiting as long as it gets sorted out.
    Mine is a Dec 07.
  12. cjp2k
    260
    25
    I have just found out that the Loan car (April 08) has the same problem!!!
    Surely this must be a coding issue as i doubt audi would have broken parts fitted to cars for well over a year?!?!
  13. Kontraband
    Kontraband Active Member
    2,008
    When I double click my open button its the same as Leons... I gotta click the boot button to open the boot...
    Will go test the slower double click right now!!
    BRB!
  14. Kontraband
    2,008
    ok, now Im just confused...
    I did the quick double click.. and only the doors opened.
    I then did the slower click and the boot unlocked! WAHOO!! :rock:
    Then I locked it... and did the fast double click and it unlocked again!??!?! :huh:
  15. bacardi
    1,139
    naaaah, i've been told by many people on here its me and not my car, obviously its you too as it would never be the car, they're perfect
  16. Kontraband
    2,008
    Oh, so theres something wrong with us then?? Damn!
  17. cjp2k
    260
    25
    Just got a call from Audi. Going to be Monday at the earliest when I get the car back. So not sure what they are doing!
  18. redbutcher
    redbutcher Member
    649
    I thought it was a coding problem and posted a scan of my car in the vag-com forum - the guys from Ross-Tech took a look and said as far as they know it looks OK to them - really wierd. I'll just let the dealer sort it I think.
  19. rich32uk
    rich32uk Member
    109
    Just out of interest I thought I'd press the unlock button for a few seconds to see what happened and all four windows wound down by a couple of inches :ohmy:....... Can anyone else achieve this instant air conditioning?... :p
  20. Kontraband
    2,008
    yeah, its just the total closure...
    hold the open key then the windows open, hold the close key and they close again. :)
  21. cjp2k
    260
    25
    Got my car back, boot fixed, however I have no Windows, Doors or indicator settings in my DIS, not happy about that
  22. redbutcher
    redbutcher Member
    649
    Weird - looks like you had the same DIS settings as me - you can change the selective unlocking in the doors option?
  23. cjp2k
    260
    25
    I could, now that options gone in the DIS!!!!
  24. redbutcher
    redbutcher Member
    649
    Nuts!
    My car is going in next Thursday to sort out the same problem - will let you know if my DIS options change....
    Slightly more worrying is the fact that my fuel cap doesn't lock when the rest of the car is locked - needless to say the car is kept off the road at the moment!
  25. giblets46
    giblets46 Member
    156
    I gave up on the standard drivers door only setting, the two presses never seemed to work (and felt stupid pressing the button loads in the rain!), never seem to have the issue after they changed it to unlock all doors on one press though.
  26. redbutcher
    redbutcher Member
    649
    Collected car this morning and all fixed.
    Mine was a coding problem - and yep, the DIS setting for doors etc. have now gone.
    So, now one press on the unlock button unlocks doors and boot and when the car is locked the fuel cap locks as well (hooray).
  27. Twizzler
    Twizzler Active Member
    489
    37
    If that's how you like it then ok, but bear in mind that the selective unlocking function is a security feature designed to allow only the remote key holder access to the car via the offside door.
  28. redbutcher
    redbutcher Member
    649
    Good point Twizzler - I only want it this way as 90% of the time I need to get in the boot at the same time as opening the car - saves me looking a tit pressing the remote 3/4 times to try and get the timing right to open the other doors :blush:
  29. bacardi
    1,139
    If my selective unlocking worked properly I'd be happy with it, as I agree, the safety aspect is good, however the randomness of actually getting the other doors to open frustrates me beyond belief
  30. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    My thoughts are the same, I activated it with vagcom and the feature was great to start with, but then realised how much of a pain it was. You go to open the boot then realise the dam thing is still locked.
  31. Kontraband
    2,008
    just to revive this thread a bit, I had an issue with my windows and boot locking... basically the windows are fixed (this thread), but I also have noticed that since they did that, the boot unlocks as it should now... :thumbsup:
    Still, the clicking of the drivers window needs sorting, which I got when I raised both windows on auto... the drivers would get to the top and click about 4-5 times.
