Excessive vacuum in crank case?
Minstadave Nov 29, 2012
  1. Minstadave
    Minstadave Member
    560
    19
    I've been getting awful MPG recently and have noticed that if I remove my oil filter cap whilst idling the cap is hard to remove, once I get it off the engine is sucking air in via the oil filter cap and the revs rise.
    Is this normal? I think I may have a knackered PCV valve. Is it a DIY replacement job?
  2. Minstadave
    Minstadave Member
    560
    19
    Anyone know if it's normal for the 2.0T to suck air through the dipstick and oil cap at idle?
  3. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    If I take mine off or pull the dip stick I the car runns rough and tries to stall... Is that what you mean?
  4. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    sounds normal to me with filler cap off.
  5. Minstadave
    Minstadave Member
    560
    19
    When I take the oil cap or dipstick out it starts sucking loads of air in and the revs rise. It's meant to run rough normally.
  6. OVRA3
    1,079
    80
    Dont think so mate, when you take off the cap it should shudder and struggle... Sure someone who knows more will be along soon
  7. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    Yes there should be a vacuum inside the engine. The crankcase pressure should always be negative so when you remove the filler cap or dipstick when the engine running it will run like a sack of **** as unmetered air (air which is not measured by the airflow meter) is entering the engine.
  8. wuta3
    wuta3 Well-Known Member
    1,131
    347
    I had a rough idle, with reeealllyyy hard to remove oil cap etc and it was the PCV. It's an easy job on your drive. I gave the tubes a good clean too because they were caked in ****.
  9. becks2012
    becks2012 New Member
    15
    Yes you require a new PCV valve the oil filler cap should not be that difficult to remove when engine on idle 5 min job
