Emissions control light following DPF and limp mode
Abbie8101 Jul 14, 2013
  1. Abbie8101
    Abbie8101 New Member
    Hi - I seem to be having the very common problem with my A4 avant tdi 170 late 2008 (new shape) that many members have had with their DPF. I have owned the car for 2.5yrs - Audi serviced. The DPF first came on in January and I managed to force a regen by driving up and down the M1.
    The light came on again a few days ago - the car also went into limp mode - so I had 3 lights on altogether. The DPF, the coil/wire one and the emissions control light. After a much longer stint on the motorway and high revs when not, both the DPF and the coil/wire lights have gone off - the car is no long in limp mode (that happened first) BUT I do still have the emissions control light on.
    Do I need to continue trying to force a regen - or has the DPF gone so far I will need to take it in for a 'clean out'?
    any advice appreciated. I'm in Halifax.
    thanks!
  2. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,116
    356
    Your dpf sensor is gone. Needs to be scanned to make sure but I wouldn't drive it like that especially hard.
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    thatll be the g450 then? they also need calibrating when fitted if that is indeed the problem. Youll need somebody local with VCDS or pm NHN to buy one :D
    NHN likes this.
  4. NHN
    29,568
    1,779
    Welcome to the site Abbie.
    I wouldn't necessarily condemn the sensor until its been scanned, it could very well be this, but find someone local to you with vcds as advised above & go from there.
  5. @udi A3
    1,819
    197
    If you want to buy anything in my classified ill scan your car for free when you collect :D
    Is spamming my classifieds allowed?!
  6. Abbie8101
    Hi all - thanks for your replies. I had no choice but to drive my car to Scotland yesterday and after a good blast on motorway, no lights are now lit. Possiby gone away but not for long I am sure. Can anyone recommend a dpf removal service in Halifax/Leeds area?
    Just to add to my woes, my a/c has now also stopped working - what a great drive back in this heat. No DPF lights but a visit to garage still required for an A/c service - never mind!
  7. dieseldoos
    dieseldoos Active Member VCDS Map User
    206
    97
    I think before you go down the removal route get it scanned. I had similar a couple of weeks ago and it was an intermitant fault with the sensor. New sensor fitted and calibrated, and lots cheaper then a dpf removal. I would only go that route if the dpf is totally gone.
  8. Abbie8101
    Thanks - looks like i need to get a full diagnostic after all. On an open trip to Leeds today, all lights re-appeared. What with limp mode and no air conditioning the car needs some help ! :) And it's only 4.5yrs old.
    Any recommendations in Halifax/Leeds area - otherwise off to Audi I go!
    Abbie
  9. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,282
    618
    We're in Stockport if that's any use :)
  10. helal786
    helal786 New Member
    24
    If your DPF is on its way out its definatly a healthy reason to remove it. Do your research and find a reputable company whos done one before as its tricky to take the DPF off.
    For me it was the best thing I did for performance and economy .
