Hi all, I've got a bit of an issue with my electric windows and central locks, so the problems are, drivers door window switches not working(passenger switch working fine) when using the key to manually unlock the door it only unlocks the drivers door then when the ignition is switched on all the doors unlock, also when the key is inserted into the door manually and held over to the lock or unlock positions the windows do not open. And my remote central locking is not working on the fob.
So what I've tried to resolve the issues are,
ive had the door card off and checked the wiring loom in the door, I did have a few breaks they was re soldered back together still same faults occurred, I've checked the continuity through the loom all the way from inside the drivers foot well up to the window motor and all is fine, I've had the passenger seat out and the carpet up, no water or moisture is present and I cannot see any green on any of the plugs or in the convenience control module, I've checked my feeds and earths and can signals up to the motor and all are present, I've also had vcas connected up it would not connect to the door control module and threw up a key 1 fault. I've changed the window motor in the drivers door and still not working. I've ordered a new switch to rule that out but is there anything else it could be? Any held but be great thanks
