Electric Window Broken (not broken clips though)
SyA3Turbo Dec 20, 2006
  1. SyA3Turbo
    SyA3Turbo Member
    167
    The other week my window decided to wind down but then on the way up stopped and made a nice grinding noise. I managed to catch it and push it back up by hand. A quick search on hear showed the problem was likely to be a broken plastic clip. Armed with some printouts and glue I set about sorting it but on stripping the door panel off found the actual wire cable that runs around the frame has snapped.
    Does anyone have any ideas if I can just change the cable or will I need a new motor as the cable feeds into there?
  2. Jamesh
    Jamesh Member
    Not the answer to your question but may be of some help, the windows broken on my S3 about 2 months ago, luckly it was just the clips. I did look at getting a new regulator, the cheapest I found was Euro carparts @ £65+vat.
  3. claudefrog
    claudefrog Member
    372
    you will need an entire regulator unfortunatly
  4. A3_Turbo
    A3_Turbo Swaying towards IHI....
    1,464
    Your lucky its just that i got stung at walton audi. for a motor regulator and the cable came off of my other door eneded up at over £400!
    Jason
  5. jcs356
    jcs356 Brum brum
    2,722
    64
    Yep, sounds like you need a new regulator. Euro Car Parts or GSF will get you the parts far cheaper than Audi, but from memory, I think you will need to drill out the old one as it is riveted in place, and then rivet in the new one? I think the detailed printout in one of the other threads (which it sounds like you have) shows exactly what to do. Good luck
  6. SyA3Turbo
    SyA3Turbo Member
    167
    Well it all sounds like a real pain in the ass to do. I might try a breakers for a whole frame unit and swap the lot as the rivets dont look like regular pop ones lol.
    Cheers for the advice!
  7. RS-S3
    RS-S3 Member
    103
    The rivets definiely not are regular ones as i found out, the car stayed in the garage for 5 days becoz the mechanics decided to do the job then realised later they couldnt get the rivets so had to wait from audi to get them...couldnt get them from any other store!!
  8. chrisb
    chrisb Member
    141
    The rivets are standard pop rivets, but quite long. I've done the regulator swap (the printout you have is probably by me....) and it isn't too hard. Took me a couple of hours.
    You need to check you have rivets long enough to pass through the regulator and the frame.
  9. chrisb
    chrisb Member
    141
    My next-door neighbour had a boxfull. Standard rivets, but unusually long. He restores Land Rovers, so had a good selection. The ones I used were longer than the originals, but fitted OK- you just have to use the rivet gun more.
    I suspect 'couldn't get' means 'couldn't be arsed looking for'.
  10. AndyMac
    9,832
    45
    I got the VAG specialist to do mine, cost £85 all in. Just wasn't worth the hassle of doing it myself to save £20.
  11. RS-S3
    RS-S3 Member
    103
    ok maybe didnt try as much as i could've but hey im a gal....its not my thing!!....:p
  12. AndyMac
    9,832
    45
    Shopping? Not your thing? You can't be a girl.
  13. RS-S3
    RS-S3 Member
    103
    Im all girl i'll have u know..... ok maybe i do get a bit bored with shopping at times...and erm i like my fast cars and erm i like footy too...but im still a girl!!...arent i? :yes:
    ps- shopping for rivets....exciting stuff!!...the possibilities!!
    right im off to wash my hair....
  14. chrisb
    chrisb Member
    141
    Not you- the mechanics.....surely they would know where to get some pop rivets....?
  15. AndyMac
    9,832
    45
    Ummm I'm sure shopping for shoes is far more rivetting
  16. RS-S3
    RS-S3 Member
    103
    actually the mechanics did check a few places...or so they said....but couldnt find any so i was without my car for 5 whole days!! :0(
  17. Pmol66
    Pmol66 Member
    258
    lol
  18. Sam_
    Sam_ Down under
    3,027
    477
    6 year bump for "lol"? Nice :)
  19. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,117
    1,956
  20. Pmol66
    Pmol66 Member
    258
    Haha! I didnt realise it was that old :DThere is method in my madness. I was just keeping the thread safe in my participated list. Im biding my time for a good weather spirt then im going to attempt this.
  21. voorhees
    16,117
    1,956
    lol sorry but its the rule when a thread this old is revived.
    Btw tools at the top can subscribe you without having to post :friends:
  22. Pmol66
    Pmol66 Member
    258
    That was funny. A bit of wee nearly come out when i seen that pic..
    ohhhhh i see in the thread tools :icon_thumright: Cheers Dude
