Econ won't go off??
Kyle. May 6, 2013
  1. Kyle.
    Kyle. Member
    70
    Tried all I can but econ won't go off? Am I missing something?
    Any ideas?!
  2. Az
    Az Hard slammed!
    1,023
    34
    How weird is that, just been away for the weekend in the mrs avant and her car is doing the exact same thing! I was getting really frustrated with it cos no matter what I did with heater and blower settings I couldn't turn off econ either, the light on the button just turns off in time with you pressing the button and then goes back on to solid light when you release your finger off of the button..... :/.
  3. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    you need either a regas
    or a sensor has ****ed up
  4. quattrojames
    14,050
    573
    It's the air conditioning shutting itself down to protect itself. If the Econ light is ON the compressor is OFF, this means the ac isn't working. This is typically because it is low on refrigerant, or one of the sensors has failed.
  5. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    As James says above.......normally low on gas
  6. Jules
    Jules Member
    130
    Mine was the same when I bought it, had it regassed and replaced the sensor all ok light went out.
  7. Paul B7
    Paul B7 Active Member
    622
    34
    I had exactly the same on my car last month. It was a pressure switch which had failed. Cost for a new switch and regas was circa £150 .
