dsg 7 oil swap recall
karlabdool Nov 15, 2013
  1. karlabdool
    karlabdool Member
    152
    19
  2. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,724
    1,628
    Doesn't affect Audi does it, I think it is only cars made in China and certain VW models...
  3. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    Curious about this for several reasons
    1. Countries & build codes & models as mentioned by cake2u
    2. DQ200 was branded as "sealed for life & no oil changes" so either that is marketing rubbish or begs the question how they change the oil.
    3. Mixing synthetic & mineral oil (at least in engines) means sludge so how are they going to get all the synthetic oil out as I assume same issue applies to gearboxes, even if time for it to develop is different. Double oil change?
    Being in the UK am not particularly worried about the "hot & humid conditions"
    Separate thread on software update helping when pulling out at junctions so will wait and see on both of these.
    John.
  4. AJB
    AJB Active Member
    175
    43
    I understand from other web pages that it's a global recall, so I'm assuming it's not just Chinese models. I haven't seen a list though. I believe it does affect at least some A1s and A3s as well.
    I think "sealed for life" in that context means that the service schedule doesn't require changing the oil or checking its level for the life of the car. That doesn't necessarily mean that it's not possible to drain or suck out the old oil and refill it, which is what they're doing here, just that you don't have to as a part of the normal life of the car.
    I'd never heard that before. You can buy semi-synthetic oils, so it must be possible to mix them. And I've never heard of people having to flush engines through when changing from one oil to another. I know mixing some coolants causes sludge, but hadn't heard it for oils.
    From another site, the issue seems to be corrosion within the gearbox causing metal particles, which can then short out electrical components. I guess hot and damp makes corrosion happen a lot faster, hence the problem in "hot & humid conditions". I think they're actually replacing the mechatronic units under recall in some hot and humid countries.
    I guess the same corrosion will happen in cooler and/or dryer countries, but just a lot more slowly. I'm assuming they're worried that problems might develop in years to come even though they haven't yet, and so are changing the type of oil as a precaution to prevent lots of failures as the cars get older.
  5. cuke2u
    5,724
    1,628
  6. karlabdool
    karlabdool Member
    152
    19
  7. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,706
    1,522
  8. h5djr
    9,397
    1,734
    This could affect Audi as well as all s-tonic gearboxes for transverse engines are made by Volkswagen at it's Kassel plant in Germany. No doubt Audi will be in touch with owners if necessary. It seems it only affects the 7-speed version and not the 6-speed used in the 2.0TDI.
  9. ACWKGYTO
    ACWKGYTO Well-Known Member
    1,240
    365
    Spoke to Audi UK today regarding my own vehicle and mine isnt affected, they said they would let me know if it was
    They pretty much said it only related to VW DSG 7
    Audi S3 P8 61 plate MY 2012 quattro black edition S Tronic (6 speed)
    I have found the gear box to be excellent no issues whatsoever
  10. cuke2u
    5,724
    1,628
    Much what I said then...
