i have aftermarket DRL's. The the "DRL" leds replace the sidelight. so when you have sidelight on you actually have the DRL leds on. If you want true DRL's then you have to wire the sidelights to a switched 12volt. this will leave the DRL leds on all of the time even when the light switch is in the off position. The only thing is with wiring them to a switched 12 volt. is that you will get bulb out warning on the DIS. I am still trying to figure out how to bypass or trick this.
