driver side rear arch rubs when there is 5 people sit in the back of my a3 s back ??
durtytdi140 Nov 7, 2011
  1. durtytdi140
    durtytdi140 Member
    66
    whenever there is 2 people in the back of my a3 sportback the DRIVERS side rear tyre rubs the arch i have no idea why and neither do the tyre places does this happen to anyone else and how do i sort this out because i want 19" alloys and if its doing this on my 18" alloys the plan for 19" alloys is cancelled
    the car is on standard sport suspension and has not been lowered or had spacers put on the wheels
    its on 18" BBS CH's originals not copies :) on 225/40/ZR 18 all road same tyres
    ive had four wheel tracking done it hasnt sorted it im stuck with a dilema
    please help me its doing my head in
  2. Brett Butler
    Brett Butler Member
    664
    13
    well it sounds like a spring shocker combination, measure the gap between the wheel arch and the ground on both sides is it the same, is it easier to push one side down compared to the other? but I would guess it is a shock absorber weak on that side.
  3. 1inchpunch
    1inchpunch Member
    451
    Is the passenger sitting on the drivers side a right fatty? :)
    Does sound very weird to get rubbing with standard sport suspension. Is it all the time or just over bumps? Have you removed the legendary rubbing screw?
  4. hades-
    9,481
    646
    thats my thought use slim ppl in the back
  5. durtytdi140
    durtytdi140 Member
    66
    haha no fattys is the car lol an im not fat either lol, hmm good idea must check distance between the floor first and check if its easier to push one side lower down than the other hmmmmm, and whats the rubbing screw :S ?? and what happens if i remove it nothing will become loose will it ? any pictures of the screw ?
    im getting a horrible extra line on my tyre as well due to this problem :(
  6. hades-
    9,481
    646
    remove the screw
    iv had to do it on all my audis
  7. 1inchpunch
    1inchpunch Member
    451
    I had Eibach springs fitted last week and it was rubbing like hell on every little bump in the road. Removed the dreaded screw and no more rub. The screw also gave me a nice line round the outer edge of my tyre.
    The screw is located right where the rear quarter panel meets the bumper. You'll need a torx bit (can't remember the exact size) to remove it. It only takes a minute or 2 to remove both and don't worry, the bumper won't fall off or flap about in any way.
  8. Ads
    Ads License to drive
    8,230
    607
    Don't just remove the screw and move on.
    Removing the screw will probably stop your rubbing but will only be disguising the problem rather than fixing it.
    Your car should not be rubbing at all if it is at standard sport height, and especially not just on one side.
    You need to get it looked at properly.
  9. moag
    moag she's no d-turbo
    821
    35
    Shouldn't be rubbing at sport height.
    Sounds like a suspension issue if its only rubbing on one side. Could be a duff shock or broken spring
  10. Shadowman
    Shadowman Active Member
    592
    43
    I may be teaching a chicken to suck eggs here, but are the BBS CH's definately the correct ET/Offset for your car ? That size wheel and
    tyre shouldn't give any problems whatsoever, regardless of how it is loaded up as it is the standard fitment for the S3 which sits even lower than the Sport......something's not right.
  11. Lings
    Lings Active Member
    2,059
    31
    My guess is a tired shock absorber
  12. Ads
    8,230
    607
    I reckon you're right.
    Open the boot and push down on the boot frame to see if your car bounces down and up more than once.
  13. grimp
    grimp Member
    142
    14
    5 people in the back... ur doin it wrong mate ;)
  14. NHN
    29,300
    1,702
    Yeap I'm with Ads & co, with your current setup, no way should the screw need to be removed, its stock so it is probably a spring or shock at fault.
  15. durtytdi140
    durtytdi140 Member
    66
    i had the car checked last night the performance garage i use couldnt find any fault with the suspension its had s line springs fitted at some point in its life not sure when so its not sport suspension i only found out yesterday, im going to remove that screw as you guys advised me and see how it is with that removed,
    the people in my car are not fat and im not fat either lol.
    the BBS's came of an audi s3 8P2 but a 3 door and there are no spacers just standard alloy wheels with the right size tyres
    not 5 in the back obviously, 3 in the back or even 2 in the back on either side and the car rubs goin round sharpish bends and bumps unless i got 3mph over them :( thats to slow lol
    i will try the screw as you guys sugested and get back to you guys cheers for the help guys :) owe you one if it works
    one more question slightly of topic but my brake pad light has come up which pads do you guys recommend all round rear and fronts ?
  16. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    I agree. If they Were a different wheel width to the OEM item then id say just remove the screw. But seeing as they are Pescaras they shouldn't rub at all.
  17. durtytdi140
    durtytdi140 Member
    66
    ill take the screw out mate and see if it sorts it if not going to have to check the camber setting, because thats the last thing i can do because i aint got a clue what else it could be
    what pads do you recommend me getting S3RYE ? because braking is a pile of S H I * at the minute lol i was wondering what the problem was and turns out the pads because the light has just come up
  18. Ads
    8,230
    607
    Like we said mate, removing the screw might stop the rubbing but it isn't going to fix the problem that obviously exists with your set up.
    With OEM Sport or s-line suspension or OEM alloys there should be NO rubbing, no matter how fast you go around bends or over bumps.
    Have you got a photo of your car side on that you can post up??
  19. S3RYE
    3,448
    70
    As ive already said. my S3 brakes.
  20. S3RYE
    3,448
    70
    +1
    your wheels should never be rubbing. I have BBS CH 8J which are half inch wider than yours. Lowered -25mm on a car which is already lower than a 2.0TDi and didnt get any rubbing. only when i added an additional 10mm (spacers) did i get rubbing. It would be safe to say there is something wrong.
  21. durtytdi140
    durtytdi140 Member
    66
    this picis the only one i have on me at the momentof the rear driver side arch if it loads
    i measured the distance of both rear arched and they are the same height off the ground
  22. Ads
    8,230
    607
    As expected... there is LOADS of space at your rear arches. If it is the screw that is catching then you've got FAR too much spring/shock compression going on at the back.
    For the last time mate............ GET SOMEONE WHO KNOW'S WHAT THEY ARE DOING TO LOOK AT IT!!!!!!!!!!!!!!!!!!!!!!!!!!! ;) :laugh:
  23. NHN
    29,300
    1,702
    With all respect, I cant argue with this as you're getting nowhere fast, something is not right, for me its still a spring or most likely shock on that side that when weight added is acting very differently to the other, no way that should rub, I mean look at it, its higher than the tip of the eiffel :p
  24. Ads
    8,230
    607
    I just replied to your email son. :yes:
  25. durtytdi140
    durtytdi140 Member
    66
    its not that high up man getting a little bit ahead of yourself there i will have it looked at because im gettin 19's soon bentleys if i can find a set of 5 spoke ones
  26. Ads
    8,230
    607
    Blackpool Tower?
  27. S3RYE
    3,448
    70
    i would sort out ride height prior to Bentleys otherwise your car will look like moon buggy
  28. NHN
    29,300
    1,702
    LMFAO moon buggy, just the mind image cracks me up, but its true what he says, if you have issues now, bentleys probably wont even turn lmfao.
  29. durtytdi140
    durtytdi140 Member
    66
    F this forum its jus abusive lol, i will look into lowering springs then aroun 15mm bit risky because i carry alot of weight in ther when i go cash and carry for my shop now and agen so cant have the car too low otherwise wont be able to get anything in there.
