DIY heat shield - for under £20
Piester Feb 23, 2011
  1. Piester
    Piester Member
    90
    With difficulty. Basically drilled two large holes next to each other to get the tin snips in, then lots of little snips later and you get a nice MAF sized hole. It's a ball ache but you get there in the end.
  2. RAPS3
    RAPS3 Well-Known Member
    1,142
    135
    Good effort mate - did something very similar a good few years ago when I had my 8L
    S3Lol likes this.
  3. badger5
    9,431
    1,975
    hmmm. oh well you tried.
    just curious how I can get the 3inch tip to fit OE airbox.. Fiddly job that it was compared to using a JR fiter (trimming was required to both silicon bends but it worked.)
  4. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Wow that looks awesome! Where did you have you airfeed pointing?
  5. JamJay
    JamJay Member
    188
    Thanks :). I am just about to invest in a pack of Tin Snips, R/H, L/H & Straight. I found a guide on the internet for cutting round holes in ducting which has been very useful.
    It would have fitted for sure but like you say, I'd have to trim both hoses and I didn't want to make a mess of the TIP or risk compromising its performance. It's fine though, I've sold the Neuspeed on and I look forward to making my own custom shield in a couple of weeks. It's currently secured using the eyelet for the OE cold cold air feed :).
  6. RAPS3
    1,142
    135
    Thanks mate - I had the air feed pointing from the end of the cone down through the inner wing and into the front of the foglight grill - was a bit tricky getting it in but worth it
  7. S90GAV
    S90GAV Member
    563
    i could knock some of these out, as im a CNC Laser operator ;)
  8. barters3
    barters3 Member
    438
    Here's my attempt, based on Geoff's but i made i few changes.
    Primed it with an etch primer for aluminium and satin black top coat. doesnt look amazing but it should do the job. just got to install a cold air feed now.
    Oh and the sticker is just to cover a mark on the aluminium, i would have preferred it to not be on there tbh.
  9. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Very nice mate!
  10. J B
    J B Member
    140
    Looks good mate, I finished mine off the other day blacks the way forward :ninja: I should get a pic!
    Where did you get the protective edging I cant find any anywhere! :(
  11. s3 man
    s3 man Member
    105
    that looks really good mate.did you use the same measurements as Geoff's and did you use ali or steel?
  12. barters3
    barters3 Member
    438
    Where did you get the protective edging I cant find any anywhere! :([/QUOTE]
    I have got an astra van and behind the seats are cubby holes with rubber edging on!! There wasnt enough to do the whole thing so i just did the straight edges as they were hard to get dead square using snips, so the edging made them look a bit better.
    Followed geoffs design, however i didnt cut the bracket into the right hand side of it, i just made both sides the same and then rivetted a bracket in place after.
  13. barters3
    barters3 Member
    438
    oh and i used aluminium
  14. sportstractor
    sportstractor Chugger
    2,709
    You can get it on eBay mate. Search edge trim, I got a few metres for £3 per metre... Bargain
  15. JamJay
    JamJay Member
    188
    How thick was the aluminium, 1mm?
    Here's my mock up, will build it this week.
  16. coyle
    coyle From Show... to GO
    435
    I think it would work better without the coupler between the MAF and the filter,
    and also, why didn't you fold the card around the right edge of the filter? you changing the shape?
  17. JamJay
    JamJay Member
    188
    The coupler is there to straighten the airflow pre-MAF to ensure further longevity of it, its widely implemented across SCN and works well. It also sticks the filter nearer the air feed which is now noticeably cooler than when it was attached to the MAF. The shield i am making is basically a Neuspeed/Jabba hybrid, best bits from both, there is no right hand wall as there is no point, the turret is enough and gives the filter more room to breathe and a larger area for the cold air to be trapped in.
  18. JamJay
    JamJay Member
    188
    Calling S3 Fran, empty your Inbox, I'm trying to reply to your message about this :).
  19. fran-s3
    1,103
    LOL sorry emptied! :)
  20. J B
    J B Member
    140
    Ok so thought I would put a couple of pics of my attempt up, I couldnt get hold of any aluminium so ended up using .6mm steel which seems sturdy enough for now :shrug: just waiting for some edging strip from ebay to just finish it off :icon_thumright: Now all I need is to sort out a decent cold air feed!
    Put two brackets on it and it sits on a foam pad on top of the cabling conduit this thing aint goin nowhere :eyebrows:
    Cheers Geoff for the kick up the backside that I needed lol kept putting it off but got it done eventually :applaus:
    VAG-Slag likes this.
  21. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Looks well JB, nice effort
  22. J B
    J B Member
    140
    Cheers Dave, the hardest part was getting the TIP to fit again had to cut both the silicon joiners down in the end, wasnt much room to play with!
  23. Westy
    Westy Well-Known Member
    17,443
    1,103
    That looks very professional JB good work. I'm going to get a Jetex filter this weekend but I'm still torn between a custom enclosure like yours or a cut and hack at the standard air box to keep the OEM look :uhm:
  24. J B
    J B Member
    140
    I did think about hacking the standard box like tuffty and others but decided it was just as easy to make a custom shield, if it was painted crackle black then I think it would blend a bit better. It might be possible to fit the old airbox cover over it which is something I hadnt thought of might look into that tomorrow :idea:
  25. Westy
    17,443
    1,103
    If you can get the old air box cover to go on your custom shield that would be ideal. The thing I dont like about hacking the standard box for a cone is that it has to be squeezed in to fit.
  26. JamJay
    JamJay Member
    188
    Here;'s my effort pre-spray painting. Fits extremely well and just what I wanted.
  27. s3dave
    10,110
    736
    Looking good jamjay,
  28. JamJay
    JamJay Member
    188
    Thanks Dave.
    Having some trouble getting the edging strip though, anyone know of any high street stores that stock it? My local RS Trade Counter does but they don't open on Saturday's.
  29. barters3
    barters3 Member
    438
    mine was a pain to get it to fit!
    I wish i extended mine towards the wing like you have, it looks much better.
    Any updates on cold air feeds would be appreciated as this is the next thing on my list.
  30. sportstractor
    2,709
  31. JamJay
    JamJay Member
    188
    Well here it is, all finished...
    fran-s3 likes this.
  32. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Very nice :thumbsup:
  33. LukeTripod87
    LukeTripod87 Active Member
    373
    52
    Anyone fancy making one of these for me as I don't trust myself? lol I'll pay well!
  34. fran-s3
    1,103
    Awesome - I want one! :) Just in time for summer eh...
  35. barters3
    barters3 Member
    438
    thats really good jamjay, just paint it black and itll look the nuts!
  36. JamJay
    JamJay Member
    188
    Thanks :). I've just repainted my Brembo's so I have the painting bug.
  37. JamJay
    JamJay Member
    188
    I have a spare one ready to go, just needs to be cut out of the template. You would however need to cut your own MAF hole as each car is slightly different, especially those with 3" TIP. Where are you located, if close I could do this for you?
  38. Inertiauk
    Inertiauk Active Member
    574
    29
    Another Job on my To Do List.
    Going to ask my dad for a hand as he's an engineer. Might even be able to knock me one up at work.
  39. Aaronipswich
    Aaronipswich Member
    Superb work guys
  40. LukeTripod87
    373
    52
    Ooo sounds tempting! :) I live in canterbury in kent mate. If all I would need to do is cut the MAF hole I'll take it mate.
