[ QUOTE ]
Gambba said:
The turbo will not increase in temperature when the engine is at idle
[/ QUOTE ]
Not after some enthusiastic driving it won't, but from cold it will. It's relative from that respect. But bear in mind a turbo off boost is a restrictive device, so some heat soak will occur.
[ QUOTE ]
Gambba said:
nor will the engine,
[/ QUOTE ]
Yes it will, otherwise your engine wouldn't get up to working temperature if you left it idling, which it does. It can even get the fans to kick in i.e. when stuck in traffic.
[ QUOTE ]
Gambba said:
The engine is at it's hottest when under load regardless of moving or not,
[/ QUOTE ]
Granted, but what about heat soak. Some of that heat will still be retained when you slow down/stop.
[ QUOTE ]
Gambba said:
yes the air flow assists, but then that's what the fans are for!
[/ QUOTE ]
The fans are there for the cooling system. Any additional airflow through the engine bay is a bonus. And bear in mind the turbo has an engine block between it and the fan.
[ QUOTE ]
Gambba said:
I let my car cool down for a couple of minutes for the simple reason is that while the fans are operating and the water pump is pumping then that means everything is being cooled, not heated up.
[/ QUOTE ]
That's providing the fan is running when you stop. If you only leave it for 30 seconds the coolant may not hit the temp at which the fans kick in, therefore you are putting more heat in there.
[ QUOTE ]
Gambba said:
I would strongly disagree about turbo's being designed and built to withstand abuse,
[/ QUOTE ]
I didn't say they were designed to withstand abuse. I said they were designed to withstand working temperatures.
[ QUOTE ]
Gambba said:
I have seen extremely large and expensive diesel turbochargers fecked up because the operator just jumped out of the machine without a cool down.
[/ QUOTE ]
Everything can be broken. That's why I said it does need to cool down if it's glowing, but if it's been subjected to normal driving conditions it doesn't. Hence the "That's what it was designed for" bit.
[ QUOTE ]
Gambba said:
keeping the turbo lubed and cool is essential for the bearings when shutting down. The turbo on the car does not stop turning just because you leave the car to idle, it will continue to rotate and lubricate itself, and when we say turbo spooling up we don't mean it goes from a standing start, we just mean the time it takes to go from it's idle speed up to 180,000-200,000 rpm.
[/ QUOTE ]
I agree. That's why you shouldn't blip the throttle then shut the engine off with the revs above idle. I realise the turbo is spinning, relatively slowly compared to when it's boosting, but leaving it there spinning slowly with the least amount of oil pressure feeding it is probably more detrimental than just turning the engine off, saving it from 2-3 minutes of slow operation in a low oil feed situation.
[ QUOTE ]
Gambba said:
Most turbo failures are down to lack of lubrication to the bearings....this is a fact!
[/ QUOTE ]
Again, I'm with you. Usually caused by people who blip the throttle on start-up when all the oil has drained from the turbo - The oil hasn't had chance to be circulated round the engine and back into the turbo. NOT from turning it off without leaving it to idle for 5 minutes.
